#1 |
![]() ![]() ![]() ![]() Join Date: Jan 2014
I just went shopping, and in the middle of my trip these codes appeared , I erased them , and the CEL immediately came back on.
Anyone ever have this happen ? What is causing this ? GTSRider Hudson Valley , NY |
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2013
2008 AURA XE
Found this explanation...Can you select them on your scanner to go deeper into the menus? Try a different scanner?
https://www.autocodes.com/qa/39930/w...-on-saturn-ion
2008 Saturn Aura XE 3.5L 4 spd 2000 Saturn SL1 1.9L SOHC (Retired) |
#3 |
Thanks for the response....I think my brother has an in-depth scanner, I can access....but I have had a stalling issue for 6 months now, and feel I have a good hunch what it is... I will replace the crank sensor soon...any day now.... when I get the time....
#4 |
2008 AURA XE
If you decide to change the crankshaft position sensor without pulling codes, be aware there is a relearn function that needs to be done.
http://www.obd2.com/support/reprog/d...turn-crank.pdf
#5 |
im..... I replaced crank sensor, and now have code PO315 ....CRANK SENSOR NOT YET LEARNED .... now over 200 miles of work commuting , and engine still stalls and coughs , but not nearly as often....but even just once can get you into a rear end accident....but anyways,,,,tried the 3-4,000 rpm for 20 seconds, and nothing seems to work.... I have a GM dealer a mile up the street from me....I would take it there if they could snych CKP with ECM.
CEL is always on.... What do you think ? GTSRider |
#6 |
2008 AURA XE
A capable scan-tool is needed that has relearn CKP variability functionality. The GM dealer would be able to do it. It's a pretty simple procedure.
The relearn procedure is mainly for misfire detection so I suppose it could affect drivability. https://www.brakeandfrontend.com/tec...set-procedure/
#7 |
Thanks IM.... you made my weekend.
Will have that done sometime next week. |
Bookmarks |
Codes codes and more codes 99sl2 | Jaybone586 | S-Series Tech | 4 | 06-06-2015 09:21 AM |
Got my codes read.. the autozone rep was surprised to see soo many codes... oh no | bskicrash1 | S-Series General | 2 | 11-12-2006 02:10 PM |
SES Codes (beyond the paperclip codes) | rkhassen | S-Series Tech | 11 | 10-18-2006 08:53 AM |
OBD II codes | santro | L-Series General | 6 | 09-27-2005 10:33 PM |
OBD II codes | santro | L-Series Tech | 0 | 08-24-2005 11:45 AM |
