#1 |
![]() Join Date: Nov 2014
2002 SL1
Greetings. I have a 2002 SL1 SOHC. Cannot pass NYS inspection due to P0410 code. I followed the richpin video. Replaced the smog pump & the switch. Clean all the way to the exhaust manifold. But it has come to my attention that the Secondary Air Injection Vacuum Control Solenoid Valve is missing the round black thing that looks like the cap from a can of brake cleaner. I cannot find this part number anywhere & the only part number I'm getting is ACDelco's 214-1057 but that is NOT compatible. Can someone please, please help me? I'm at the very end of my rope. Thanks so much.
#2 |
2002 SL1
Now I am starting to think the part number is 2121-0001. This could make sense since the diverter itself is 2121-0000.
I've found a bunch of GM parts website, most of them are using the same search software & most are coming up with the same part/# but no image so I can't be sure. However, there are two more websites using this part number for the actual diverter, not the solenoid....and again, no images. I don't trust any of them but I trust you guys. I mean, this forum helped me believe, understand, convince others, and then finally resolve the whole "camshaft position sensor" problem. I really need help with this. I'm way overdue on my inspection & my car IS my livelihood. It's only a matter of time before I get bagged by the cops & then I would lose my job. Please help??? Thanks. |
#3 |
I am unsure of the part #, but here's one on E-bay:
http://www.ebay.com/itm/2001-2002-sa...xYpglt&vxp=mtr It comes with the valve. I'll check my Alldata account to see if they have a P/N.
'97 SL1, 136K, Auto, Mint Green (SOLD 146K) '99 SL2, 126K, Auto, Silver (SOLD 149K) '97 SL1, 136K, Manual, Burgundy (Gifted to Brother 138K) '02 SL2, 149K, Auto, Light Gray/Silver |
#4 |
2002 SL1
Thanks Bachands! I found another thread where OldNuc says the part number is indeed 2121-0001.
I'm not allowed to post links to other sites & this is a similar thread on this same site. I'm removing the first part of the URL just leaving the rest. I think you guys can find it. /forums/showthread.php?t=229607 This thread can be locked or deleted. I hadn't seen the other thread when I posted. Thanks again. I'm gonna contact that seller to ascertain if it works. There's nothing in the description. Last edited by Pegasus83; 04-05-2017 at 10:07 PM. Reason: Adding link to similar thread on this forum |
#5 |
Identification of parts.
#6 |
![]() ![]() ![]() Join Date: Feb 2018
2004 ION-2 Quad Coupe
sorry to dig up an old thread
![]() im in the same boat with replacing this switch. everything i find says CALIF EMIS LEV(NC1), Fed EMIS NLEV(NF7) https://www.ebay.com/itm/Secondary-A...bab2%7Ciid%3A1 is this part still gonna be compatible with my Michigan based car? all the other details fit my car but that CALIF EMIS worries me
2004 Saturn Ion Redline 2002 Saturn SC1 2002 Chevrolet Trailblazer 1980 Ford Pinto Prostreet |
#7 |
![]() ![]() Join Date: May 2004
Err, I'm not too knowledgeable about this system, but...
I Think the only difference between Cali vs Federal emissions would concern the CatCon behind the flex on the downpipe -- it has more precious metals to purify the Ex stream. [the O2 sensor circuitry may also be more sensitive??] The manifold-mounted 'precat' serves Only to pre-heat the main CatCon on coldstart. OldNuc examined the operation with an infrared thermometer, and found it quickly becomes 'incandescent' hot right after starting, and then shuts down. So, the valve you seek to replace would have the same function for either Fed or Cali emissions vehicle --- either CatCon needs preheat. I think I may have bought one from RockAuto. I later discovered it was working. The Relay in UHJB turns the valve on, i think. In my case, the first failure/intermittency in the SAIS was due to poor contact/connection in the forward/psgr Ground Splice Pak on the frame member behind headlamp that the air pump grounds to. The second failure/intermittency in SAIS was due to extra resistance at relay contact blades in UHJB, which was rectified by removing/reseating the relay into UHJB. I later installed a new relay (I'm cheap, but feel generous about any component which endures >150kMi, or 15 years service)! Last edited by TomM96; 01-17-2021 at 02:48 AM. Reason: fergat un |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
How can it shut down?
Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018 |
#9 |
I presume it stops getting air injected and cools down
#10 |
Ah, that makes sense. Thanks!
#11 |
> it stops getting air injected...
Walker Exhaust has a very brief overview description of how the CatCon systems evolved. They wrote that early cats were designed to operate on engines running somewhat rich. All gas engines with camshaft timing for >3000 rpm require a rich mixture for cold starting. So the preheaters on our Sats receive rich mixture at coldstart, and the rich exhaust is met with a fresh air blast, and the weakly coated (precious metals) preheater much accelerates the combustion in the exhaust stream. Then the air blast cuts off, and the mixture leans out. The location of the precat would be ideal for a primary/main CatCon, Except that it would make life challenging for the radiator, ignition, and cooling system. So, I think out precats have only a little bit of the precious metals (palladium, platinum, rhodium), only necessary for the conditions at coldstart. On some later engines, many with the vee-six configuration, the Main CatCon is located close to the ExMan. Toyota and Ford use the config ... a mechanic reported that they never fail, while the catcons behind/below the powertrain frequently cool down if the car drives through a puddle. |
Bookmarks |
Secondary Air Injection check valve | greenman | Aura General | 9 | 02-25-2013 06:12 PM |
secondary air injection valve | namato1 | Ion Tech | 2 | 02-09-2013 01:07 PM |
secondary air injection valve | Frez | Ion Tech | 3 | 08-12-2012 09:47 PM |
P0410: Secondary Air Injection Shut-off & Check Valve question | pdxsl2 | S-Series Tech | 3 | 01-05-2010 10:00 PM |
Vacuum at fuel injection valve | 94sl2guy | S-Series Tech | 8 | 09-18-2004 02:25 PM |
