#21 |
What company is that? And where on Saturn Motorsports?
#22 |
i am interested in this tune!! so please stop the tease!!
06 ION-2 Sedan 5 speed- miles increasing * 20% Tint all around * * RACTIVE Dual Tip Exhaust * * 8000k HID kit * * 17' Drag DR14 wheels on 225/45/17 * http://www.cardomain.com/ride/2374384 |
#23 | |
![]() Quote:
2004 Saturn Ion-2 QC www.ionforums.net - Forum For Saturn Ion Owners |
#24 |
![]() Join Date: Mar 2006
2006 ION-2 Quad Coupe
i would rather have my computer cracked and get it tuned in my car instead of haviing it sent out im not sure how well they can tune for f/i.. but i can get shipping at cost
VISIT MY CARDOMAIN --> http://www.cardomain.com/ride/2259877 s256 turbo, vulcan intake, exedy clutch, 8.9:1, camed, eagle rods, 2.4 tb, B&G coilovers, patriot head, stage 2 axels 418whp 2.2 :) |
#25 | |
![]() Quote:
+rep always appreciated! The Procharged Ion - http://kickassion.bc3tech.net 16.317s @ 85.30mph (Nearly stock) 188.28whp / 175.03wtq - SMP Stage 2 - 10psi |
#26 |
![]() Join Date: Oct 2006
2005 ION-3 Sedan
I have a 2005 ION 3 sedan... does that 2.2L ecotec fit mine too? or just the coupe?
#27 | |
![]() Quote:
#28 |
Alright, that's it, **** modifying my Ion, I'm getting a damn Suzuki GZ 250.
#29 | |
![]() Quote:
Thats just wrong! You can't do that, there are still possibilities without a tuner.
#30 |
I'm just tired of all the crap right now. I figure, get into motorcycles for a while, when I check back in a few months/years from now, there will be plenty, and then I'll build my Ion up to be a real monster.
#31 |
If you want tuning for the e16a ECU, please post here (by REQUEST of the providers! wow!):
http://www.sctflash.com/forum/showthread.php?t=7575
+rep always appreciated! The Procharged Ion - http://kickassion.bc3tech.net 16.317s @ 85.30mph (Nearly stock) 188.28whp / 175.03wtq - SMP Stage 2 - 10psi Last edited by bc3tech; 12-22-2006 at 02:45 PM. |
#32 |
![]() Join Date: Nov 2020
2004 ION-3 Sedan
Is there a possibility of my 04 ion sedan 2.2 being tuned I would love to have it done instead of giving up
#33 |
![]() ![]() ![]() ![]() Join Date: Apr 2000
2007 ION-2 Quad Coupe
1997 SC1
I'm not sure how much gain you can really make via calibration changes on a naturally aspirated motor without also changing hardware parts too. Most of the gains you read about via tuning are cranking up turbo boost and other changes that add fueling to go with it.
#34 |
Ionben570, are you aware of asking questions in a thread started in '06, 14 years ago that hasn't been answered at all? All idle speculation. The 2.2L GM ecotec engine is used in several models. None are super or turbo charged from the factory.
The 2.0L engine is the only factory turbocharged engine in a small block. There's more to super or turbo charging engines than just adding boost. Quite a bit more than most diyers are willing to learn. Unfortunately, the majority that make attempts learn the hard way as most engines are blown from not spending time to understand major differences between naturally aspirated and boost in a custom setup. In addition to having access to the ecm or pcm (if they're not locked permanently as most Saturn engine computers are), assumptions of access to 2.2L ecm may reveal another major issue - they're not accessible otherwise this thread would have revealed it back in '06). Locking an ecm usually means an alternate way around it by piggy backing an aftermarket computer or starting from scratch, eliminating the factory ecm and wiring in an aftermarket ecm that's completely tunable at higher cost. With EFI systems. the map sensor is crucial to factory n/a engines as well as factory boosted engines except boost uses a different map sensor. If you don't know about vacuum in n/a engines and then boosting with positive pressure requiring a different map sensor as well as access to the ecm for tuning then you're already behind the learning curve. Try keeping a perspective. In 14 years, no one found a way to break the 2.2L ecm for boost. You can always search other GM forums for models using the same 2.2L engine and see if anyone has more info. And then search for GM forums using the 2.0L factory boosted engine and if any tunes were made for additional power. |
#35 |
![]() ![]() ![]() ![]() Join Date: Jan 2014
Does anyone make a simple bolt on turbo kit for a 2.2 ION ?
#36 |
![]() Join Date: Mar 2014
2003 ION-1 Sedan
2006 ION Red Line
Zzp does. Can also use the saab 9-3 set up
I'm just a guy that enjoys my Ions. Try Google, first. Then ask. |
#37 |
![]() Join Date: Mar 2021
Trifecta can tune these cars. They just don’t do in depth tuning anymore for it. I had them tune mine last year, just a 91 octane tune, nothing fancy. Maybe with enough support they would do more again?
Bookmarks |
Tuning!!! | 2006 ion2 | Ion Mods | 39 | 02-10-2011 09:02 PM |
tuning | msbplane | Ion Mods | 14 | 09-13-2008 02:11 PM |
Possible tuning? | FGCA_XRL | Vue Mods | 14 | 07-24-2008 07:32 AM |
Tuning | klever402 | S-Series Mods | 17 | 05-01-2006 08:50 AM |
Tuning?? | Edgey | Mods and Performance | 6 | 07-14-2005 06:51 PM |
