Old 12-29-2017, 11:19 PM   #1
CarolinaVue
CarolinaVue is on a distinguished road
2008 VUE 3.6L
Default 2008 Vue Wheel Speed Sensor C0035
Sharing general info - My 2008 Vue (3.6L V6, 211k miles) was giving a trouble light for both ABS and TCS. Code was C0035, Left Front Wheel Sensor Circuit. My code reader and this forum advised the (3) most common fixes were to replace the wheel speed sensor, the WSS wiring harness, or the hub and bearing assembly.
1st step - unplug the WSS (behind the wheel), and spray both plugs with contact cleaner. No luck - trouble codes persist.
Next step - replace the hub and bearing assembly (with integrated wheel speed sensor). Cost $130 at local NAPA. Found a helpful YouTube video by 1A Auto for bearing/hub replacement on 2008 Chevy Equinox (FYI - exactly the same for my 2008 Vue for this job - provided torque specs, bolt sizes, and everything). Installed new hub, took car for a quick spin, and both codes immediately cleared. Problem solved. Despite the car being ten years old with 211k miles, the old (original) parts were easy to remove (no rust or seizing). Probably due to living its entire life in the south haha.
#1 - thanks to all on this board for posting their knowledge. Very helpful for an amateur driveway mechanic like me.
#2 - not sure whether anyone has experience with the BlueDriver code readers, but I bought one on Amazon for $100. It was the cheapest one I could find that read ALL trouble codes (including ABS, TCS, etc) in addition to MIL "check engine" codes. You download the free app to your smart phone, plug the reader in to your OBD port, link the reader to your phone's bluetooth, and control the reader from your phone. Told me exactly where the problem was, and suggested specific fixes. Very simple to use. See screenshot attached of phone screen after reader reported the C0035 code.
Posting this info as a "re-payment" of sorts after lurking the forum for a few days working on this fix. Hopefully it helps someone.
2008 Saturn Vue 3.6L V6, 211k miles, still running strong. 2nd owner. Replaced 6T70 transmission at 205k.
CarolinaVue is offline   Reply With Quote
Old 01-24-2018, 02:30 PM   #2
Saturn072014
Saturn072014 is on a distinguished road
Default Re: 2008 Vue Wheel Speed Sensor C0035
Thanks for the post. I seem to have the same code now. Did your old wheel bearing feel bad when you replaced it? Mine feels in really good shape but I already replaced the sensor and wiring up from the sensor without fixing the code c0035.
2009 XE 2.4 Saturn Vue.
Saturn072014 is offline   Reply With Quote
Old 02-06-2018, 07:45 AM   #3
dmayorgap
dmayorgap has a spectacular aura aboutdmayorgap has a spectacular aura aboutdmayorgap has a spectacular aura about
dmayorgap's Avatar
2008 VUE 3.6L
Hi, great post! 3 days ago i got the ABS, Traction Control, Stabilitrak and AWD lights in the dashboard, almost sure its a wheel speed sensor but i dont have BlueDriver to probe it, so today im going to the dealer to scan the VUE.
David M.
Chevrolet Captiva Sport AWD V6 3.6
dmayorgap is offline   Reply With Quote
Old 02-06-2018, 03:47 PM   #4
dmayorgap
dmayorgap's Avatar
2008 VUE 3.6L
Hi, Dealer says they pulled out a lot of codes from different modules, the root cause from all of them is low voltage from the generator/alternator, anyone had this similar case?
Thanks
David M.
Old 02-08-2018, 08:34 AM   #5
Saturn072014
My issue turned out to be in the hub assembly some where as the ABS light went out after replacing the hub.
Also see my other related thread here: http://www.saturnfans.com/forums/sho...d.php?t=233631
Old 02-21-2021, 09:10 PM   #6
patrickstapler
patrickstapler is on a distinguished road
2008 VUE 3.6L
Apologies for reviving an old thread. My wife’s ‘08 XR V6 6 speed auto is having similar issues. I don’t have a sensor tester so I dove right in today. Replaced the rear sensors which didn’t solve the problem. Started on the fronts and realized I couldn’t remove the sensor.
Does the entire hub assembly have to be removed to get the front sensors out?
Kind Regards,
Patrick
patrickstapler is offline   Reply With Quote
Old 02-21-2021, 11:50 PM   #7
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Caliper, caliper bracket and rotor have to come off to gain access...
https://www.youtube.com/watch?v=Rzep_Paqjvg
Old 02-22-2021, 11:24 AM   #8
patrickstapler
2008 VUE 3.6L
Those dust shields and the sensor location are different than mine. The dust shield on mine comes with 1/4” of the sensor and cable. Once the sensor bolt is removed, there is no way possible to remove the sensor. Wish I would have taken a picture. I think what I am going to do is use my high speed burr and remove enough material from around the cable so the sensor can be removed and the connector will pass through. This has to be one of the worst designs I have seen.
Kind Regards,
Patrick
2008 Vue C0045 Left Rear Wheel Speed Sensor Code bz1lvn 2008 Vue 3 08-11-2017 12:14 PM
Wheel speed sensor Kwillis Astra Tech 2 05-30-2017 02:23 AM
Why do I have a wheel speed sensor?? jjroyer Vue General 17 08-12-2012 04:04 PM
wheel speed sensor bigdude2468 2008 Vue 1 03-31-2012 03:00 AM
ABS wheel speed sensor warrenc Ion Tech 18 12-22-2011 12:06 AM
