Old 01-09-2017, 11:20 AM   #1
xdarkxfirex
xdarkxfirex has a spectacular aura aboutxdarkxfirex has a spectacular aura aboutxdarkxfirex has a spectacular aura about
Default Voltage drop problem
Replaced battery and alternator recently, get 13-13.9v with car on. On my scan tool it shows the voltage at the control module is higher, but it doesnt output that amount. Checked all cables for resistance, wear and they are good.
Problem is battery drops instantly when car is off. Usually its 12.1-12.4v, but when I let it sit in the cold, its around 11.5-12v
xdarkxfirex is offline   Reply With Quote
Old 01-09-2017, 08:03 PM   #2
xdarkxfirex
Default Re: Voltage drop problem
Edit: Did drop test and got between 40-60milliamps letting it rest
Odd Voltage drop issue 700+SL2 S-Series Tech 27 11-04-2016 12:37 PM
voltage drop when increasing RPMs to 3K visnew20 S-Series Tech 0 07-18-2012 07:22 PM
Rough Idle In D, Voltage/RPM Drop Decaf S-Series Tech 6 02-23-2012 12:49 AM
Has anyone experienced voltage drop in closed loop? mgordon1100 S-Series Tech 19 10-27-2010 11:59 PM
Depressing clutch causes voltage drop kornphlake S-Series Tech 18 07-20-2006 02:34 AM
