#1 |
![]() ![]() Join Date: Jul 2014
Hi guys, I'm new here. My names Daniel.
I have a 01 LW300 V6 which I just swapped the engine due to timing belt breaking, now no start no crank. No fuel pressure at rail and no 12 volts at starter or park/nuetral safety switch. Ignition key is missing key fob remote. Any ideas?? Thanks in advance Daniel |
#2 |
1-Did you check every wire harness during the engine swap, battery connections, all engine/chassis grounds? Checked for blown fuses in all three fuse panel locations?
2-Can you hear the faint hum/hiss sounds of the pump running for 2 seconds when ignition is first turned on? Depressing the fuel test valve is another way to see if fuel pressure develops when a pump runs. Saturn fuel pumps do not run continuously with ignition ON engine OFF. Starting allows the EFI system to turn on pump operation.
VCX NANO |
#3 |
yes, but one i cant find it is a male two prong connector with a purple and yellow wire, it only has one inch of slack off the harness its right on the trans near the connectors for the coil packs. It has 5 volts when the key is on. Any ideas?
No all I hear is the throttle body |
#4 |
The throttle body enters an automatic calibration mode (slight whir) after ign is left ON (engine off) beyond 30 seconds.
Here are two drawings with the same yw/ppl wires but different plugs.
VCX NANO |
#5 |
Ya it s the throttle body making noise.
The connector is right where the trans and engine meet under the manifold. Im baffled, it right near the water distribution pipe?? |
#6 |
Did you mouse over each thumbnail and click on it to open a larger view of the two connectors?
VCX NANO |
#7 |
Yes it does not look like either of them
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2011
2001 SL2
is the crank sensor plugged in????they tend to flop down and be missed.. this moter will run with out a cam sensor but won't fire without crank signal..
shure you can trust the government,just ask us indians all about it... heavy line the final protective fire line of the dealership |
#9 |
crank pos sensor is plugged in, im gonna try old crank sensor see if it works.
#10 |
Problem finally solved.
Signal wire from the alternator that send voltage to starter solenoid was damaged, I replaced the wire and fusible link and starts like normal. Thank you all for your help Remember to always check the basics first. Daniel |
Bookmarks |
02 LW300 engine issue | ktetch | L-Series Tech | 49 | 01-09-2014 12:56 AM |
2003 LW300 Starting Issue - Mystery No Start | TVCCS | L-Series Tech | 3 | 01-10-2013 01:06 PM |
Engine Swap...first attempt at starting | vickyvp | S-Series Tech | 5 | 11-30-2010 02:48 PM |
'02 lw300 engine needs rebuild at 80,000 | rnelson | L-Series Tech | 4 | 02-11-2008 04:00 PM |
Front seat swap 2001 LW300 | sunfish | L-Series Tech | 4 | 12-30-2006 11:54 PM |
