Old 06-11-2012, 12:48 PM   #1
dhunch
dhunch is on a distinguished road
Default Saturn 2001 Sl1 manual Transmission shakes starting out in 1st gear
I replaced my clutch disk, and throw out bearing about 5 months ago. For the past couple months after the car heats up, it sometimes shakes as you go to start out in first gear. After you start you do not have any issue driving or switching gears, just starting from a dead stop. And It does not always do it. It is a strong shutter. Any ideas
dhunch is offline   Reply With Quote
Old 06-11-2012, 02:43 PM   #2
trottida
trottida's Avatar
Default Re: Saturn 2001 Sl1 manual Transmission shakes starting out in 1st gear
Did this start around the time you started using A/C (assuming your car is equipped)? Could you be feeling the lost power being directed to run your A/C? Just a thought.
1999 SL2 MT (311,300 km @ 01/2023)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 06-11-2012, 02:51 PM   #3
BV22
2002 SC1
What is the condition of the top engine mount? A collapsed one can let the engine jiggle.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Old 06-11-2012, 05:44 PM   #4
ddeuces22
ddeuces22 is on a distinguished road
transmission mount should be checked as well
96 sl2 stage 1 midpenn cams,91/92 header,2.25 ss exhaust, ported and polished head, groundpounder, sda bones, pimped tranny mount, .40 o/s pistons, .25 u/s rods, .25 u/s crank,19mm progress swaybar
ddeuces22 is offline   Reply With Quote
Old 06-27-2012, 09:40 AM   #5
dhunch
The engine mounts look good. And it only occurs sometimes. I can't tell if it is coming from the back wheel or the front. Sometimes it really shutters alot.
Old 06-27-2012, 09:43 AM   #6
dhunch
Plus I have noticed when coming to a stop, I can feel a vibration in the brake pedal. But the rotor doesn't look warped at all.
Old 06-27-2012, 10:37 AM   #7
Might be the caliper guide pins. Those need to be replaced, too. Use a good, synthetic brake grease (like sil-glyde, which OldNuc recommended). You may need to clean out or replace the rubber boots as well.
Won't shift out of 3rd gear...manual transmission. born2b2b Vue General 3 09-07-2011 02:05 PM
Transmission starting in too high a gear? ericbryanwiggin S-Series Tech 9 06-30-2011 09:45 AM
Manual Transmission REFUSES TO GET INTO GEAR. HELP!! Jerz3455 S-Series Tech 2 10-17-2007 11:35 PM
Manual transmission - grinding 3rd gear Vijay SC2 General Saturn Discussion 1 07-21-2007 08:36 PM
2001 Saturn L100 2.2L Manual Transmission Headaches cybercyst L-Series Tech 5 11-24-2006 09:28 PM
