![]() Join Date: Nov 2022
I have a 2000 Lw2 with the v6 and the "sport package" without sunroof.
What is all needed to lower one of these cars ? Is there any coilovers available? Does anyone know if the Opel Vectra 2 wagon coil overs or a body kit will work ? |
My guess, maybe asking the Opel Vectra forums overseas.
Our L300s are based on the Vectra, making L300s a foreign import with mods for USA bumper and lighting standards. Over the years, I've found our forum members sharing their knowledge with parts not available here, are sold in Europe suggesting most parts are interchangeable.
#5 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2015
2002 L-Series 3.0L Wagon
The back comes down easily but the front struts are too long from the factory. The fronts struts from an Ion are shorter but I have not personally experimented with them yet. If you drop the rear you will need adjustable lower arms to get the camber correct. The toe sets at the leading end of the trailing arm. Most alignment shops do not have the correct information on these cars and will try to shim it. I like suspension travel since my cars are daily drivers but I do not like the factory rake on the sedans.
2002 LW 300 loaded, only 95,000 original miles! 2002 L200/5 Loaded, 275,000 miles 2000 LS1, TMU love those bcm failures. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2014
The Saturn is based on the Opel Vectra B model. Only use that designation for comparison purposes. Later Vectra models are NOT compatible.
It's also worth pointing out that the suspension, braking system, etc is also shared with the Saab 9-5 and the Saab 9-3. The Saturn was marketed as a safe, family car so had little appeal to modders. That distinction was given to the Saturn S series. However, in Europe, the Opel and sister brand Vauxhall Vectra B's were the staple of the company car fleet and sold by the truckload as Reps cars. That meant in Europe there is a healthy aftermarket for tuning these vehicles, whether suspension or drivetrain/engine mods. So you should do research on the Vectra B, Saab 9-5 and Saab 9-3. That may give you the results you want. Here's a link you may find useful: https://www.ebay.com/itm/272833298603 |
#7 |
![]() ![]() ![]() ![]() Join Date: Mar 2015
I tried using struts from a 2003 L200 that usually sit lower in the rear than the 2000-2002 models. Well it did positively Nothing ! I think the Ride Heighth is controlled by something else than struts, whether it's the stabilizer bar or whatever. Anyway, didn't lower anything. I also thought about trying rubber spacers in the front springs or new front struts. Usually the rule is that if you raise the front slightly, the rear goes down. Also have tried 205/60 tires on the rear. That helps as well. Whichever you choose, DON'T heat or cut the springs, that doesn't work well on water, snow and ice ! lol.
Looking for S-Series Sprint Lowering Springs | SmokeySL2 | Classifieds | 0 | 12-11-2021 11:55 PM |
FS: S-Series Intrax Lowering Springs | JDub99SL2 | Classifieds | 6 | 06-04-2015 12:22 AM |
Lowering a Saturn S-series | 96SL1 | S-Series Mods | 25 | 10-28-2006 06:02 PM |
02' - 04' L- Series Wagon Recall | ricksLS1 | L-Series General | 1 | 06-13-2005 03:43 PM |
S-series wagon | davidsky | S-Series General | 42 | 09-05-2004 09:47 PM |
