#1 |
I had a question about cleaning it, since I had been having a bit of trouble with shifting....and was going to get down around the filter to check on the tranny fluid temp sensor connections after the p0711 code at me.....can you just spray some electronic parts cleaner around it to clean it?
The streets will flow with the blood of all the non-believers!!!! And all those who won't include their vehicles vital information in their posts!!!! |
#2 | |
![]() Quote:
Unless you are getting an oil soaked wiring harness/wiring at the connector you should be able to leave it be. For the P0711 if you don't find any damaged wiring at the trans temp sensor make sure that the engine temp sensor is good. The trans, engine and air temp sensors are used to compare to each other for this code.
A lousy day in paradise is still a day in paradise. |
#3 | |
![]() Quote:
Bookmarks |
Top Engine Mount...Check. Tranny Mount???? | fixit4mywife | S-Series Tech | 5 | 06-03-2008 09:35 AM |
tranny end plate gasket verification | adhsc2 | S-Series Tech | 4 | 09-03-2007 01:38 PM |
transaxle buss plate slightly melted | mehalski | S-Series Tech | 2 | 08-07-2007 09:30 PM |
Buss Plate | bruce633 | S-Series General | 3 | 12-31-2005 04:20 PM |
Buss plate | bruce633 | L-Series General | 2 | 12-31-2005 12:35 AM |
