#1 |
![]() Join Date: Sep 2006
Well I need help / guidance on this. Yesterday I posted the following:
http://www.saturnfans.com/forums/showthread.php?t=89795 Today I got to another Autozone and they were able to read it. I read the machine and it said: P0303 - Cylinder #3 Misfire Detected My problems just started yesterday. However note that about 2 months ago I changed and did the following: Changed ECTS Changed Oxygen Sensor Changed PCV Valve Did the Mystery oil cylinder thingie as well. Along with regular oil, oil filter and air filter change. Things were going good since I did all of this for a couple of months now. Yesterday it started acting weird, as I described in the post. Kinda twitchy, jittery or something. So, now I have more info thanks to the computer. But to be honest I cant say I know the best and cheapest way to proceed. I need guidance on the easiest and cheapest things to try first. I have done some reading and I know the following things are common suggestions: Check and changed spark plugs - Consensus recommends NKG V I believe? Spark plug wires? This I just am not sure about, don't know what to check or order from Autozone. EGR valve? Again not sure how to check it or replace it yet. Compression tests? Is this hard to do? Expensive equipment? I will ask father in law, retired mechanic for help on this. So best order to do these things? Quickest and cheapest things are my friends since this is the worst month of the year to have any added expenses. Any help is going to be greatly appreciated! I will keep reading and see if I can figure some of this out on my own in the mean time. |
#2 |
![]() Join Date: Nov 2005
2004 VUE 2.2L
2008 AURA XE
How long since your last tune up?
If it's been a while maybe it's time to install new plugs and plug wires. Clean any cororsion off the coil tower tips, that could cause the misfire too. If you detect oil in your spark plug wells then a new cam cover gasket is in order. Review the how to library; do a search Wolfman has a great how to post there.
Previously Owned 98 SL2, Sold 98 SL, Sold When your Saturn is well kept YOU are well kept. Second Car: Buick LaCrosse 2006 |
#3 |
^^^^ Ditto. If the problem persists, remove and exchange the two coil packs with one another. After that, the problem will still be a P0303, or you'll instead get a P0301, which is cylinder 1 misfire (the tower that used to serve #3 now serves #1). If the problem indeed moves to #1, that coil tower needs to be cleaned further, or that coil pack is just bad.
You might also have an injector problem with #3. When you remove the plugs, smell each one, and be esp. sensitive to the smell of unburned gasoline. If you do smell unburned gas on #3, that injector could be leaking, soaking the plug. |
#4 |
Recently got P0303 code on 1999 Saturn Sl1. I had to drive 70 miles with the engine sputtering. Made it home.
Found the problem to be spark plug wire. Wire on cylinder #3 was rusted and fell apart when pulled on. Will get it replace. Glad it wasn't a major problem. Given the age of the car, the wiring connections seem the most vulnerable. Any other likely wiring connection to get rusted ? |
Bookmarks |
How is misfire detected on Saturn SOHC? | Tommie | S-Series Tech | 2 | 05-07-2009 08:59 AM |
P0303 misfire | alain173 | S-Series Tech | 1 | 04-17-2008 01:18 AM |
#3 cylinder no firing P0303 OBD2 code | Blammer | S-Series Tech | 51 | 03-07-2008 12:13 PM |
OBD Code: P0301 Cylinder 1 Misfire Detected | hc803 | S-Series Tech | 16 | 01-22-2007 12:25 PM |
#3 misfire P0303, | crewleader1 | S-Series Tech | 7 | 03-24-2006 05:22 PM |
