Old 03-27-2006, 08:48 AM   #1
Steedo
Steedo is on a distinguished road
Default Throwing Code 19, ideas?
Hey, I've been trying to breath new life into a 93 SL2 that has seen much better days. It had a plugged up exhaust which has now been fixed, new ECTS, new plugs and wires, and typical maintence (oil, filter, etc). I'm having random no-start situations and and while driving the tach will jump around, drop out, and then the car just dies. I replaced the CPS, as all things I have found have pointed to it being the problem. I do see spark between the plug wire towers. It is currently throwing a code 19, which I read at differentracing's site. Any ideas?
Steedo is offline   Reply With Quote
Old 03-27-2006, 09:03 AM   #2
softspot
softspot is on a distinguished road
1997 SL1
Default Re: Throwing Code 19, ideas?
19 is crankshaft position sensor , according to my code book.
softspot is offline   Reply With Quote
Old 03-27-2006, 09:10 AM   #3
softspot
1997 SL1
wrong book sorry , knock sensor.
Old 03-27-2006, 11:08 AM   #4
Steedo
what book would that be?
The info I have is this:
http://differentracing.com/tech_articles/dtc/19.html
Could you elaborate on why it would be the knock sensor?
I'd rather not run out and spend $50 on a new one, any way to verify it is indeed the knock sensor?
Old 03-27-2006, 11:58 AM   #5
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Judging by what it says on out site, I'd go with the crank position sensor. A code 19 is a 6x signal fault and the CPS generates that signal.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 03-27-2006, 12:02 PM   #6
Steedo
yeah, as I said, I replaced the CPS, brand new one, still has the problem
is there an easy place I can sniff the CPS signal? it isn't that easy getting to the sensor with a meter...
I think I'm going to remove the ignition coils and module and clean them up again
Old 03-27-2006, 09:46 PM   #7
Steedo
So I did absolutely nothing but clear the codes, took it out for a spin tonight and it seemed to run fine! Just seems to be low on coolant...
03 Vue throwing code P0128 mattwiant Vue Tech 12 12-15-2009 09:10 PM
Throwing Code 20twinz Ion Tech 2 10-29-2009 06:16 PM
Vehicle Speed sensor replaced and still throwing code. Triggamane S-Series Tech 11 05-17-2009 04:06 PM
Code throwing, but is it actually correct? groingo S-Series General 2 04-30-2009 07:07 PM
Throwing code P0410 Mike88 L-Series Tech 0 09-23-2007 11:40 PM
