#1 |
![]() Join Date: Oct 2001
Where is the sunroof drain hose located on a '96 SC2? I think my girls sunroof may be leaking and that was my first thaught to check. Thanks.
#2 |
![]() Join Date: Jan 2001
The drain hoses are located at the front of the sunroof towards the front of the car. If you open the roof, looking at it from above there are 2 holes, one on each side at the front corners. There have the drain hoses connected to them that run down the A pillar and out the bottom of the car. These do occasionally get clogged and a blast f compressed air will clear any debris. You can check to see if they are cloagge dby taking a jug of water and with the roof open, pour it around the opening. The water should drain out the bottom of the car. If it sits there, the drains are clogged.
#3 |
![]() Join Date: Feb 2001
you may want to check the front left corner of the sunroof glass.There is a hole on the glass frame near the edge of the glass sealing strip(unserviceable)that is supposed to be sealed and in many cases it leaks right through the seal and through the frame.From there it drips on the headliner.Another way to check is to run water over the glass(shut of course) and see if water seeps through the edge of the frame.The only correct fix I know of is replacing the glass itself.
Bookmarks |
How do you get to the front sunroof drain tubes? | demoncamber | S-Series Tech | 6 | 10-10-2009 08:22 PM |
SC clean SR drain hose, with sunroof closed? | k1hog | S-Series Tech | 1 | 08-22-2009 10:34 AM |
Clogged Sunroof Drain Lines | Gumart1 | S-Series General | 16 | 07-28-2009 07:46 AM |
Where are sunroof drain hoses for '93 SL2? | Leadsled Coupe | S-Series General | 0 | 10-07-2005 07:35 PM |
Sunroof Drain Plug | beensmoked | L-Series Tech | 1 | 02-03-2005 02:18 AM |
