Old 12-22-2005, 07:06 PM   #1
tenn734
tenn734 is on a distinguished road
tenn734's Avatar
Default Where to Ground Wire ?
I'm trying to install an auxiliary cigarette lighter http://www.awdirect.com/awdirect/fin...m?itemid=10008
Im planning to tap into the inside fuse box for power using something like this
http://www.autotoys.com/x/catalog/FU...ON_p_4932.html
where would be a good place to ground it? im guessing the metal frame that supports the radio & a/c... is safe / recommended?? where else if not there.
i got sick of only being able to use one cup holder when charging.
tenn734 is offline   Reply With Quote
Old 12-22-2005, 11:39 PM   #2
Default Re: Where to Ground Wire ?
There are bare metal support brackets aroung the in car fuse block that are already being used for ground points so they would be ideal.
Old 12-23-2005, 12:02 AM   #3
getz999
getz999 is on a distinguished road
getz999's Avatar
yes, a bolt should be holding down a large ground wire (which is the ground for multiple things in your car) unbolt it, "splice" your ground into the esisting ground wires and tighten the bolt back down.
If you dont have access to a ratchet, you can solder it to the frame itself, or even hold it down with electrical tape <----not too smart
getz999 is offline   Reply With Quote
Old 12-23-2005, 12:20 PM   #4
tenn734
tenn734's Avatar
cool thanks
Old 12-23-2005, 12:21 PM   #5
tenn734
tenn734's Avatar
cool thanks
Old 12-23-2005, 12:22 PM   #6
tenn734
tenn734's Avatar
cool thanks
Burnt ground wire to ignition kenkennings S-Series Tech 1 05-12-2009 09:15 AM
ground wire question bigbfarm S-Series Tech 7 03-30-2009 01:16 PM
ground wire upgrades petdmc S-Series General 13 04-18-2007 04:13 PM
Best place for ground wire 97SatGuy S-Series Tech 6 04-06-2007 03:39 AM
Ground Wire Questions lpradiohead S-Series Tech 7 01-16-2005 12:34 PM
