Old 01-12-2005, 11:12 PM   #1
lpradiohead
lpradiohead is on a distinguished road
1999 SC1
Default Ground Wire Questions
Hello all,
I am scrubbing down all of my ground connections on my 99 SC1 and have several questions. First, on my negative grounds, what should be connected to the ground post? That is, I have my battery cable on my ground near my fusebox AND a small black wire around the ground post. Is this normal? An accessory I do not know about? Second, on my negative ground connected to the engine I have my battery cable AND another cable; is this normal? Third, if these are supposed to be there (which I think they are), what should be the order that they are connected? Should the battery grounds be touching the metal first, followed by the other connections? Does it matter? And, if I may be so bold, my last question: does anyone the best way to get to the ground beneath the air filter? It is nigh impossible. Thanks.
lpradiohead is offline
Old 01-13-2005, 12:33 AM   #2
wolfman
wolfman's Avatar
Default Re: Ground Wire Questions
Is this normal?
YES
YES
Thickest wire (as clean as you can reasonably get it) on the bottom, thinner wires on top, then the nut. NOTE: Generally any wire that needs to be connected direct to chassis (or engine) GROUND will have an RING (aka: eyelet) connector on the end of it AND be black in color.
wolfman is offline
Old 01-13-2005, 01:09 AM   #3
sierrap615
sierrap615's Avatar
here is a diagram of all ground locations - http://www.saturnfans.com/photos/sho...hp/photo/17765
remove the entire air box and its right there
sierrap615 is offline
Old 01-13-2005, 03:27 PM   #4
Thor4SL2
Thor4SL2 is on a distinguished road
Thor4SL2's Avatar
While we are on the subject of ground wires, is anyone using the ground kits they sell on eBay and other places? Are they anything more than cosmetic? If so how are they installed, to what points?
http://cgi.ebay.com/ebaymotors/ws/eB...946824814&rd=1
Also is there any advantage to putting dialectic grease between the wire(s) and the ground point?
It's not what you know that counts,
it's what you think of in time!
Thor4SL2 is offline
Old 01-13-2005, 05:35 PM   #5
eljefino
eljefino's Avatar
1995 SW1
The ebay ground kits are junk; if the factory knew the car would run better with more grounding they'd have done it in a heartbeat.
If I had a ground apart and cleaned up, I'd reassemble it dry so the fastener would have less chance of coming loose. Any goop to keep water out I'd apply from the outside.
eljefino is offline
Old 01-14-2005, 01:05 AM   #6
sierrap615
sierrap615's Avatar
they would work if you had a rusted-thru beater from the 70's. they would connect to the points in my link above.
Old 01-16-2005, 11:05 AM   #7
geeze
geeze is on a distinguished road
Dielectric grease is used to keep moisture out and to reduce oxidation of the connection, not increase conductivity. Only apply to connection after it is made and torqued down. Good connections are made by freshly cleaned components. Use either sandpaper or a Scotch-Brite pad (my favorite).
There is a high conductivity grease available. 1/2 ounce costs $40. It is made up of micro-fine (1 micron) 99.9% pure silver. Purchase through McMaster Carr. It is a rare case where this would be needed so diagnose carefully and correct the problem first.
I have had electrical problems source right down to the fuse level where there was excessive oxidation on the fuse which reduced the conductivity to a level where supplied components wer fed low voltage. Good PM to clean alll fuses / relay when you change out a battery. You would be suprised the difference it can make.
geeze is offline
Old 01-16-2005, 12:34 PM   #8
Razorbak
Razorbak's Avatar
On the contrary, dielectric grease is specifically designed to not conduct electricity. That's why it makes such a good insulator for spark plug boots, because it prevents spark jumping and carbon tracking. Here's the official definition...
"Dielectric"
Razorbak is offline
ground wire question bigbfarm S-Series Tech 7 03-30-2009 01:16 PM
ground wire upgrades petdmc S-Series General 13 04-18-2007 04:13 PM
Best place for ground wire 97SatGuy S-Series Tech 6 04-06-2007 03:39 AM
Burned Ground wire to Ignition apeskull96 S-Series Tech 10 09-06-2006 08:53 PM
Where to Ground Wire ? tenn734 S-Series Mods 5 12-23-2005 12:22 PM
