Old 01-09-2005, 11:57 PM   #1
pjpcvp
pjpcvp is on a distinguished road
Default Transaxle drain plug location
Greetings everyone.
Can someone please tell me where exactly the transaxle drain plug is located? I have a 1996 sl2 standard. According to the owner's manual they show a picture of an automatic transmission with the drain plug facing to the left, away from the exhaust. I checked underneath and found what seems to be a drain bolt but it faces toward the exhaust. But there are a few other bolts and I don't want to start undoing the wrong one. Aslo, there is no mention of a filter for a manual. Can someone please advise? Thank you.
pjpcvp is offline
Old 01-10-2005, 12:01 AM   #2
Razorbak
Razorbak's Avatar
Default Re: Transaxle drain plug location
Originally Posted by pjpcvp
Greetings everyone.
No filter, and the plug is on the passenger's side of the vehicle, facing the exhaust. The big wide flanged bolt in the middle left of the following photo, right in front of the dark fluid leak on the trans case...
http://www.saturnfans.com/photos/sho...at/500/page/39
PS - the trans drain plug on the left looks very similar to the oil drain plug on the right.
Razorbak is offline
Old 01-10-2005, 12:06 AM   #3
pjpcvp
Thank you for the response!
pjpcvp is offline
Old 01-10-2005, 01:04 AM   #4
Razorbak
Razorbak's Avatar
Thanks. Glad to help.
BTW, just to avoid confusion, I meant to say the trans drain plug is on the passenger's side of the transaxle case, not the passenger's side of the vehicle. It is the plug on the left of that photo, facing the exhaust pipe. The plug on the right of the photo facing the rear of the car is the oil drain plug.
Razorbak is offline
XR Transmission Fluid Change-Drain Plug Location CT Aura XR Aura General 5 07-12-2009 08:04 AM
location of transmission fluid drain plug on 03 ION ASIN? sgb Ion Tech 2 10-18-2008 04:57 PM
Location of oil drain plug on 2004 Ion 2 Rocky0529 Ion Tech 6 10-27-2007 11:50 AM
Stripped transaxle drain plug - HELP! jm0397 S-Series General 7 10-27-2003 03:47 PM
Transaxle drain plug torque:20 or 40ft lbs?Chiltons vs. Haynes auxmike Miscellaneous Tech 4 04-04-2003 01:16 PM
