Old 09-25-2000, 06:26 PM   #1
cyberbill
cyberbill is on a distinguished road
cyberbill's Avatar
Default Engine Compartment Cleaning
What does anyone suggest to use for cleaning an engine compartment?
-Bill ('97 SL2)
cyberbill is offline
Old 09-25-2000, 08:13 PM   #2
sattech
sattech is on a distinguished road
Default
Whatever you use, be careful around the top of the cam cover with water. Quite often when cleaning the engine water flows under the plug wires and into the plug wells causing a severe misfire
sattech is offline
Old 09-26-2000, 08:39 PM   #3
Roger '97SL2
Roger '97SL2 will become famous soon enough
Default
I use Simple Green. Put it in a spray bottle. Spray it on and wash it off. Do watch the valve cover. You may want to pull the plug wires after and make sure that they are dry.
Now I have a question. That I thought of the other day when cleaning my car. How do you clean the insulation that is under?
Any thoughts?
Roger '97SL2 is offline
Old 09-26-2000, 08:46 PM   #4
cyberbill
cyberbill's Avatar
Default
Thanks guys for the help.
Cleaning the insulation might be tricky since it seems to be a kind of hi-temp cloth. I know that with my old van I used to drive it seemed to peel off later in its life. It was like trying to clean paper. (kinda tough)
-Bill
Old 09-30-2000, 08:02 AM   #5
verbose
Guest
Posts: n/a
Default
Do you mean cleaning the insulation on the underside of the hood? If so, simply spray a detergent cleaner on it, then hose off. The water quickly runs down and off. Doesn't do any harm.
Old 09-30-2000, 02:51 PM   #6
traveler
traveler is on a distinguished road
Default
I am planning on buying a product called the "Steam Buggy". It is basically a household portable steam machine that can be used on various household items like in the bathroom and kitchen to clean and sanitize without the use of chemicals and soap. I am planning on using it on the engine compartments as many professionals use steam and you can easily control the distance and pressure used. It does the very best job at removing grease and buildup as well as salts and general gunk off of the engine compartment safely and precisely.
traveler is offline
Old 10-12-2000, 12:20 PM   #7
sffd14
sffd14 is on a distinguished road
Default
I USUALLY USE ONE OF THE TIRE FOAM CLEANERS. THIS WORK REALLY WELL ON THE RUBBER AND IT SHINES THE REST OF THE MATERIALS UP NICELY. JUST SPRAY ON LET SIT FOR 15-20 MINS THEN WIPE OFF EXCESS. LOOKS BRAND NEW. MINE HAS 143,000 MILES ON IT AND IT LOOKS LIKE A NEW ENGINE. GOOD LUCK!!!!
sffd14 is offline
NEED engine compartment cleaning edzdallas S-Series General 5 06-11-2006 07:02 PM
cleaning my Ion engine compartment jaman Ion General 8 01-06-2006 04:55 PM
Detailing engine compartment? 1993 S-Series General 8 01-27-2005 07:31 PM
Help, something loose in engine compartment. ProDarwin Miscellaneous Tech 4 06-10-2003 05:32 PM
Engine Compartment cleaning littlebob Miscellaneous Tech 9 07-27-2001 12:12 PM
