Old 07-18-2015, 11:42 AM   #1
Logan Savage
Logan Savage is on a distinguished road
Default Sunroof drain hose observations 2004 Ion
I read several threads about the sunroof drain hoses so I decided to check mine . I removed everything necessary to pull the front of the headliner down . I found the headliner is fastened to the roof with velcro fasteners . All the velcro fasteners that were glued to the headliner pulled loose from the headliner & stayed fastened to the velcro that is glued to the roof . I glued them all back in place on the headliner with super glue .
All 4 of the sunroof drain hoses were in place & connected as they should be . I also found a small open tube on each side of the front corners of the sunroof . They seemed to come from the front center area of the sunroof , around the front corners of the sunroof & stopped with the end open . Anyone ever seen these tube / hoses & know what they're for ?
I repeat , they are not the drain hoses that connect to all 4 corners of the sunroof .
Logan Savage is offline   Reply With Quote
Old 07-18-2015, 12:49 PM   #2
oxyhydro
oxyhydro has a spectacular aura aboutoxyhydro has a spectacular aura aboutoxyhydro has a spectacular aura about
oxyhydro's Avatar
2005 ION-3 Quad Coupe
Default Re: Sunroof drain hose observations 2004 Ion
Pics help alot, what was the reason you took it apart?
support your local 81!
oxyhydro is offline   Reply With Quote
Old 07-18-2015, 01:34 PM   #3
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2006 ION-2 Sedan
The sunroof motor pulls /pushes on a cable on each side of the sunroof frame to operate the glass position. When the cables move passed the motor the tubes house the end of the cables
Old 07-18-2015, 05:29 PM   #4
Logan Savage
Thanks , I couldn't imagine what their purpose was .
Old 07-18-2015, 05:30 PM   #5
Logan Savage
Just wanted to make sure the drain hoses were securely connected .
Old 07-18-2015, 11:00 PM   #6
oxyhydro
oxyhydro's Avatar
Ok, yea i never looked whats under the headliner but i had to take the covers off on the sides of the windshield so i could pull the line from the finder an was careful not to pull them out the top, i wrote a thread on how i got mine unclogged cuz they sometimes get clogged often depending where you live, i do know that all 4 go into these angled 3" drain tubs like you can easily see in the truck ( the pieces that stay in the frame that the drains to goes to, an can easily pull those out the back) i know the front has them to witch makes it kinda impossible to unclog them by stick line through the tube an cant really get to front ones
Old 07-19-2015, 01:37 PM   #7
Logan Savage
The hoses have a rubber boot type end on them that has a small slit for the water to seep out of . Several threads I read people suggested trimming the slit end off the boot so it wouldn't get stopped up .
I did this on the back ones & am going to do the front . A couple people said if you remove the front wheel & the plastic splash shield to the rear of the inner fender the front hoses are easily accessible to snip the ends .
Sounds a lot easier than doing it from inside the car .
I just replaced the transmission & had those splash shields removed & they are held in place with plastic pins that are easy to remove & replace . Wish I had read about snipping those ends while I had it apart .
Old 07-19-2015, 02:59 PM   #8
oxyhydro
oxyhydro's Avatar
Yea those slits in my boots were like fused together from heat an dont know how water even got threw it lol, i pushed a pencil threw mine so it widened the slits... the ones in the front yea you can take off the splash gaurd an look in there an see the very tip of the boot slit, but i pulled my hoses out of those to unclog the tubs an when i put them back down the area it came from im not sure if they even went back in the boot ( it shouldnt hurt anything if they didnt cuz its still running out side the car an shouldnt be draining on anything important)
96 sl2 drain tubes on sunroof dddaaa S-Series Tech 7 10-26-2011 01:43 PM
A/c drain hose Albiem S-Series General 2 03-08-2010 09:03 PM
SC clean SR drain hose, with sunroof closed? k1hog S-Series Tech 1 08-22-2009 10:34 AM
Where are sunroof drain hoses for '93 SL2? Leadsled Coupe S-Series General 0 10-07-2005 07:35 PM
Sunroof drain hose gunny S-Series Tech 2 02-12-2002 05:41 PM
