Old 06-23-2015, 04:41 PM   #1
Bently
Bently is on a distinguished road
2000 SC1
Dizzy **sunroof leak not!!! Drain tubes**
Hello,
I have had my sunroof out for an overhaul and to fix the leak issues. Everything is back in and there seems to be water coming in when it rains around the motor itself. It looks like it is coming in where the cog wheel is and will run down and drip off the bottom support bolt. This will drip into the cup holder. Has anyone ever heard of this? I have searched the forums for hours and the only thing people talk about is the drains. I have had the sunroof open and poured a copious amount of water in the channels, the drains work very well. Any suggestions?
Bently is offline   Reply With Quote
Old 06-24-2015, 12:45 PM   #2
blue92
blue92 will become famous soon enoughblue92 will become famous soon enough
1992 SL1
Default Re: **sunroof leak not!!! Drain tubes**
The sunroof has a metal edges where the seal attaches. Sometimes they get rusty and will not seal well. But I would think it should still get caught in the drip tray. Going from memory here, could it be getting past where the bolts attach to the motor.You might have to have the headliner off to see where its leaking.
92 SL1 original owner
94 SL2 Homecoming
98 SC2 White Hot
02 SC2
blue92 is offline   Reply With Quote
Old 06-24-2015, 02:34 PM   #3
Bently
2000 SC1
Default Re: **Sunroof leak not!!! Drain tubes**
Thanks for the reply, I have the headliner out. I have been driving it without to find this leak, (I had it re upholstered). I just pulled a rust free glass with a good seal around it from the junk yard and put it in. I was wondering why the drip tray wouldn't catch it either. It is leaking from the motor, like I said in the op, It looks like it is coming in where the cog wheel is and will run down and drip off the bottom support bolt. I don't get how it is getting to it though, should I loosen the bolts and move the whole assembly forward with the glass out?
Tags
sunroof water leak motor
L200 Sunroof drain tubes jfortin L-Series Tech 2 01-09-2015 10:01 PM
Sunroof rear drain tubes ends at???? Nomad2day S-Series Tech 10 11-16-2014 09:16 PM
96 sl2 drain tubes on sunroof dddaaa S-Series Tech 7 10-26-2011 01:43 PM
sunroof drain tubes drg S-Series General 5 05-19-2010 08:43 PM
How do you get to the front sunroof drain tubes? demoncamber S-Series Tech 6 10-10-2009 08:22 PM
