Old 05-08-2003, 03:39 AM   #1
ProDarwin
ProDarwin is on a distinguished road
Default Rattling from engine compartment.,,,
Sounds almost like a tin can rattling. It was there before I pulled the motor, and I though it was the tensioner, so when the motor was out to install the manual, I replaced it. Anyways, the motor is back in now, and it is still making the same ugly rattling noise. Any suggestions?
-Travis
ProDarwin is offline
Old 05-08-2003, 04:15 AM   #2
SLeepr
SLeepr is on a distinguished road
SLeepr's Avatar
Default
ARe you sure it's not the cat? The only noise I can think of that sounds even close is when my catalytic converter pooped the bed.
SLeepr is offline
Old 05-08-2003, 07:45 AM   #3
Marlin1975
Marlin1975 is on a distinguished road
Default
Take the belt off and start it up. If it still makes the noise then it is not anything that is run by a belt as in bad bering.
If the noise go's away then you have something spinnig that is bad.
Marlin1975 is offline
Old 05-08-2003, 09:13 AM   #4
bbarbulo
bbarbulo is on a distinguished road
Default
Ya, I get this UGLY noise... comes on only in Drive at a light, about 3-5 seconds after I fully stop. If I roll, there is no noise, or if I'm not stopped for an extended period there is no noise. I'm pretty sure this is recent too... but I think it's exhaust, and the engine mount working in unison to create a resonance throughout the car so everything shakes rattles and rolls
bbarbulo is offline
Old 05-08-2003, 09:34 AM   #5
skijay
skijay will become famous soon enough
Default
I had a problem last summer with the 97 SL2 auto. When the car was warming up and I would shift into gear, I would hear this vibration type rattle that I could not seem locate as it resonated inside the car. I at first thought it was the AT.
After a trip to the dealer, the rattle was traced to the driver's side headlight assembly. Apparantley there was a bolt that corroded and that was causing the rattle. They replaced the bolt and no more rattles.
skijay is offline
Old 05-08-2003, 08:58 PM   #6
ProDarwin
Default
Doesn't sound like the cat. Sounds distinctly like it is coming from the right side of the engine compartment.
-Travis
Old 05-09-2003, 09:29 AM   #7
bbarbulo
Default
perhaps the lower dogbone mount is in need of looking at? This rattle... can you be more specific... like someone said other things can rattle too, like my tail lights on my SL2 were soooo loose when I bought the car, and I though it was just the plastic body that rattled under heavy bass... turned out to be my tail lights. Check everything.
bbarbulo is offline
Old 05-09-2003, 10:21 AM   #8
simtech
simtech is on a distinguished road
Default
I had this noise. When I investigated it I found out my whole timing system had started to fly apart. The chain guides were completely gone, the chain tensioner was frozen in position, the crank gear was missing some teeth, the chain was stretched, and had I left it any longer the chain would have eaten a hole in the water jacket. Check your timing components.
simtech is offline
Old 05-09-2003, 11:59 AM   #9
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Default
I get a similar ticking type of noise that only comes in when im between 2500-3000 RPM, after 3k rpm, my intake and exhaust noise either drown it out, or it goes away. I'm not sure but I think it may be some valve noise, or possibly some noisy fuel injectors?
2011 Audi TT (modified)
2007 Mercedes E550 (stock)
1999 Expedition (Stock)
2007 Ion Coupe (Daughters eventually)
Applefool is offline
Old 05-09-2003, 12:01 PM   #10
Applefool
Applefool's Avatar
2006 ION Red Line
Default
I forgot also to mention that the addition of the AEM CAI increased this ticking noise to a point of some annoyance when driving at low speeds -
Old 05-09-2003, 03:14 PM   #11
psybapunk
psybapunk is on a distinguished road
Default
same here, but I put in a hotshot...
I'm pretty sure its the EGR valve operating normally, but the metal intake amplifies the sound, causing annoyance...
psybapunk is offline
Old 05-09-2003, 07:25 PM   #12
ProDarwin
Default
Anyway for me to test if it is the EGR?
-Travis
Old 05-09-2003, 09:36 PM   #13
wolfman
wolfman's Avatar
Default
There is a BRACKET where the exhaust down pipe from the manifold to the cat connects to the lower transaxle/cradle attachment point. There "should" be a bolt/nut tightly holding the bracket plate to the bracket...any chance it's not?
wolfman is offline
Old 05-09-2003, 11:04 PM   #14
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
Default
EXACTLY what is happening with my car. Only it occurs only under acceleration and not just cruising. I think it rattles from 2K-3K rpm. I don't know what the heck it is but its not valve noise cuz I don't get any noise at idle.
-96 SC2 gets 35 mpg mix city/hw.
sps SOHC is offline
Old 05-10-2003, 02:02 PM   #15
ProDarwin
Default
Nope not the braket. I'm concerned that it is the timing chain tensioner. Maybe at 206k miles, its time I re-do my timing chain.
-Travis
Old 05-10-2003, 02:37 PM   #16
SLeepr
SLeepr's Avatar
Default
Yeah, a new timing set would be a good idea.
SPS SOHC, this is also a possibility for your situation.
SLeepr is offline
Old 05-11-2003, 12:29 AM   #17
ProDarwin
Default
Wait. Now that my good mechanic friend has looked closer at it, he said it could be the bearings in the water pump going bad. The sound got much louder after I put on a new belt tensioner. Any thoughts?
-Travis
Old 05-11-2003, 12:33 AM   #18
wolfman
wolfman's Avatar
Default
Remove the belt and turn the waterpump pulley by hand while trying to wobble the pulley in/out up/down on it shaft. It should turn smoothly and have VERY little or NO "wobble"
wolfman is offline
Old 05-11-2003, 09:54 AM   #19
myoung
myoung is on a distinguished road
myoung's Avatar
Default
I got the cat thing too, and I thought it was something in the engine at first. It's really loud at idle in drive and on low rpm acceleration. Also very embarassing.
myoung is offline
Old 05-11-2003, 10:49 PM   #20
sps SOHC
sps SOHC's Avatar
Default
I don't think so. I think the mechanic is an ***** and doesn't know what he is doing. I think the noise is coming from the tens. pulley. The same mechanic put a new pulley in 12K miles ago so I don't know why it would need to be changed already. Also I was charged $40 extra the second time around for the same part. inflation??? I think not.
sps SOHC is offline
Washed my engine compartment The Critic S-Series Tech 7 02-21-2008 11:31 PM
Engine Compartment Rattle ChiliPepperSC2 S-Series Tech 0 10-27-2006 10:13 AM
NEED engine compartment cleaning edzdallas S-Series General 5 06-11-2006 07:02 PM
Detailing engine compartment? 1993 S-Series General 8 01-27-2005 07:31 PM
noise in engine compartment cincysaturn Miscellaneous Tech 1 03-02-2003 11:53 PM
