#1 |
![]() Join Date: Sep 2011
i HAVE HAD A PUDDLE OF WATER ON THE PASSENGER SIDE FLOOR. i WENT TO A GMC DEALER WHO IS SUPPOSED TO BE CERTIFIED ON SATURNS. THEY BLUE OUT THE DRAIN LINES. AFTER A RAIN STORM TWO DAY'S AFTER IT WAS BACK AGAIN. i HAVE BEEN BACK TO THIS DEALER 3 TIMES THE PROBLEM IS STILL THERE. I NEED TO KNOW WHERE THE ENDS OF THE DRAIN LINES IN THE FRONT. I TOOK OFF THE KICK PLATE AND TRIED TO LOOK FOR THE LINES BUT NO LUCK. PLEASE HELP ME I THINK THIS IS A PROBLEM FOR A LOT OF SUNROOF OWNERS.
#2 |
![]() ![]() Join Date: May 2009
2004 VUE Red Line
2004 VUE Red Line
The drain exits behind the fender, between the antenna and the door hinge. take the splash shield from around the wheel opening and you should be able to see it.
I think you can see the tube from the inside with the kick panel off. It would be up high, near the level of the glove box. You could have a split drain tube behind the trim around the edge of the windshield.
2007 STS-V 2006 STS 1SC 2005 STS 1SE MRC, ACC, HUD |
Bookmarks |
sun roof drain cloged | rustydrip | Vue General | 9 | 08-26-2015 12:52 PM |
Wet floor boards, is sunroof drain lines the problem? | k1hog | S-Series Tech | 3 | 09-08-2009 10:15 AM |
Clogged Sunroof Drain Lines | Gumart1 | S-Series General | 16 | 07-28-2009 07:46 AM |
Battery Drain on 2002 Vue | jdurham | Vue General | 8 | 06-09-2005 12:24 PM |
FS: injectors, drain lines, turbo manifold, wideband, etc... | tristanlee85 | Classifieds | 4 | 04-26-2005 09:22 PM |
