Old 06-14-2011, 08:05 AM   #21
Default Re: P0304 cyl 4 misfire detected
Change the coils and if you also picked up An ICM change that also. As there is only #4 that is misfiring this is either an ignition or injector problem. Plug wires could also be the cause. If they are not new change those also.
Old 06-14-2011, 01:20 PM   #22
97sl2DOHCaut1.9
97sl2DOHCaut1.9 is on a distinguished road
Ok. I picked up the 2 coils, the ICM, and new plug wires so i'll change it all. BTW the compression looks ok right ? Thanx
97sl2DOHCaut1.9 is offline   Reply With Quote
Old 06-14-2011, 02:34 PM   #23
Compression looks good and the first 3 plugs are good and #4 is only slightly cold from misfires.
P0303 - Cylinder #3 Misfire Detected d4rkf1ber S-Series Tech 3 11-25-2019 04:14 PM
P0300 Random Misfire detected - What to do??? kim_lombard Ion Tech 11 07-09-2016 08:01 AM
How is misfire detected on Saturn SOHC? Tommie S-Series Tech 2 05-07-2009 08:59 AM
Infamous 4th cylinder misfire - P0304, Your Thoughts? Growser S-Series General 6 03-29-2009 11:56 PM
OBD Code: P0301 Cylinder 1 Misfire Detected hc803 S-Series Tech 16 01-22-2007 12:25 PM
