Old 05-17-2010, 07:30 PM   #1
drg
drg is on a distinguished road
2001 SL2
Dizzy sunroof drain tubes
well since all the rain we have had over the weekend in Mo. the entire floor in the car on the right hand side is soaked...checked all the sunroof drain lines and found the right rear is not connected to the sunroof module..Now do I have to take the headliner down to access the conection. or can i just remove the glass and acess it from the top...btw the sunroof does not work..thanks
drg is offline   Reply With Quote
Old 05-17-2010, 11:08 PM   #2
almoore
almoore is a jewel in the roughalmoore is a jewel in the roughalmoore is a jewel in the rough
1994 SC2
Default Re: sunroof drain tubes
You might be able to gently pull down the headliner in the right rear.I think it is just velcro that holds it up.
"No good deed goes unpunished"
almoore is offline   Reply With Quote
Old 05-18-2010, 02:22 AM   #3
macbox
macbox will become famous soon enough
macbox's Avatar
I would take the whole thing down and inspect them all while you are fixing the one drain tube. Sunvisors, map light, and dome light all have to come down, side trim has to be pulled out far enough to make clearance for the headliner, and some instructions say to take the top dash panel off for extra clearance. Seat removal would be a bonus and make the job easier, you'll need an E10 Torx socket for the seat bolts.
#4, "Betty" 1995 SC2m, 167K, rebuilt engine, Garage Queen. Still squeaks and rattles but goes like hell.
macbox is offline   Reply With Quote
Old 05-18-2010, 12:26 PM   #4
braddojm
braddojm is on a distinguished road
You shouldn't need to do anything with the headliner.
The problem is usually debris collecting at the end of the tubes where they exit the car. I had the same problem - passenger side floorboard wet after rain. Just took off the kick panels on both sides and cleaned out the bottom of the tube - there is a little piece with a screen in it that the hose connects to.
Use the search forum feature and you can find plenty of pics and diagrams....
This thread has a diagram:
http://www.saturnfans.com/forums/sho...d.php?t=140011
braddojm is offline   Reply With Quote
Old 05-19-2010, 12:35 PM   #5
drg
2001 SL2
yeah i was hoping the end was clogged up. but no the whole hose comes sliding down the roofline ...ugh
Old 05-19-2010, 08:43 PM   #6
SLCraig
I would just take down the headliner and re-secure all of them.
Once you do it once, its not a big deal. I did mine, and I'd do it again if I had to.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Sunroof rear drain tubes ends at???? Nomad2day S-Series Tech 10 11-16-2014 09:16 PM
How do you get to the front sunroof drain tubes? demoncamber S-Series Tech 6 10-10-2009 08:22 PM
Where are sunroof drain hoses for '93 SL2? Leadsled Coupe S-Series General 0 10-07-2005 07:35 PM
Sunroof Drain Plug beensmoked L-Series Tech 1 02-03-2005 02:18 AM
Sunroof drain hose gunny S-Series Tech 2 02-12-2002 05:41 PM
