#1 |
![]() Join Date: Jan 2010
Hello. I'm new to the forum and have a problem with my daughter's 99SC2. My daughter drove it until the head gasket gave out a couple of weeks ago. After doing all the work to it, It idles rough and is hard to keep started. This is what I did to it:
New head, intake, exhaust and valve cover gaskets New timing set Had head machined/milled new water pump new hoses/belts new coolant temp sensor I had replaced the plugs and wires about 6 months ago. So, when I try to get it going, it starts but runs real rough and I have to feather the throttle just to keep it running at all. About 3 minutes in, the check engine soon light blinks, and the car will run without me on the throttle, but it's real rough. I get code P0304 when I test it. I pulled the plugs and all 4 are black sooty. Any ideas? The fact that it has been well below zero here for a long time doesn't make matters easier. ![]() |
#2 |
Thats a missfire code. Compression numbers?
New head bolts also were put in correct? |
#3 |
Sorry, forgot to mention that I did replace the head bolts as well. Didn't get compression numbers because I can't get the engine hot to do it.
#4 |
Well, I fixed it. Went out and pulled the valve cover again to recheck that the timing was right (f on camshaft pulley aligned with gasket surface and pips at 12 o'clock) and it was. So, I went back to check each rocker/lifter combo and found the rocker on #4 was cockeyed on the lifter. Took a screwdriver and easily popped it back on even and it started right up, runs great! Took it to the gas station and back, no issues. No oil leaks and had lots of power. Hopefully everything remains good.
#5 |
Very nice! Good job.
#6 | |
![]() Join Date: Mar 2008
1994 SC1
![]() Quote:
94 SC1 1.9L SOHC GM Blue Green 278,429 miles 32+/- AVG/MPG |
#7 |
#8 |
Originally Posted by usafaviator my daughter's 99sc2. ... Quote: Originally Posted by usafaviator found the rocker on #4 was cockeyed on the lifter. ??? I don't understand what you mean by ??? To better explain, the rocker was cockeyed on the lifter when I tightened it down after replacing the cams/head/head gasket. This, obviously, was affecting the way the valves on #4 were opening and closing, thus causing the P0304 (misfire on #4). I popped the rocker back flush onto the lifter and retorqued the bolts. Runs great, can barely hear it run and has good power and no leaks. Last edited by USAFAVIATOR; 01-11-2010 at 05:01 PM. |
#9 |
A DOHC engine doesn't have rockers.
#10 |
99 and up do in an odd sort of way. They are very similar to the system that is used in the SOHC.
#11 |
#12 |
Y'learn something new every day: http://www.saturnfans.com/photos/sho...29210/size/big . Bears little resemblance to the topside rockers on the SOHC. I can see the need for this; when they moved the cams inward, they couldn't relocate the valves for "real estate" reasons, so they came up with this.
#13 |
The only thing that hold that rocker in there is the hydraulic lifter and the end of the valve stem. Several have been found to be out of position.
The roller cam followers are a result of the impending loss of ZDP from engine oil scheduled for 99. That did not materialize but Saturn spent the $$$$ to redesign the head. This was another expense the company could ill afford. I believe GM did this redesign to several other engines also. |
Bookmarks |
95 sc1 rough idle ses code 26 help | twwhited | S-Series Tech | 9 | 11-15-2009 04:23 PM |
P0300 code and rough idle | jakelabob | Ion Tech | 1 | 02-06-2009 01:40 PM |
Sat SL1 P0301 CODE ROUGH IDLE | docusn1 | S-Series General | 4 | 12-17-2007 08:30 AM |
Rough Idle and P0410 code | storm_amoure | S-Series Tech | 21 | 11-17-2007 10:50 AM |
Code P0300... Rough Idle | mrb277 | L-Series Tech | 1 | 07-09-2006 10:48 AM |
