#1 |
![]() Join Date: Oct 2009
2007 ION-3 Sedan
2000 L-Series 3.0L Sedan
Is there a way to drain ALL of the coolant from my 2000 LS3 V6? The radiator drain only lets out 1 gallon. Most cars have a drain on the engine block but the Haynes manual doesn't mention it (as usual). I have seen this posted before w/o an answer.
#2 |
2007 ION-3 Sedan
I guess that I have to reply to my own post. Two local dealers said that they use a machine to do the coolant flush for about $70. They had no info for a block drain. I am going to drain what I can from the radiator petcock, refill with distilled water ($1), run for a day, repeat 3 times and top up with dexcool ($15) after the last drain. $20 total. Any thoughts?
#3 |
The FSM doesn't point to any engine block drain and recommends draining coolant from the radiator petcock using a 3/8ths diameter hose over the drain tube to allow draining into a container. As you know, less than a gallon of coolant will drain out so two flushes would be more than enough for a complete flush if the original coolant was in good ondition and not discolored. I recall only flushing once and seeing close to clear water draining out before refilling with a gallon of straight coolant and using distilled water for make-up. I did mine on an inclined driveway so it may have been possible to have drained more than a gallon.
VCX NANO |
Bookmarks |
Coolant Drain Plug | Fox Slaughter | S-Series Tech | 7 | 09-19-2009 12:01 AM |
How much coolant in the if I drain the radiator | johnyrrr | S-Series General | 3 | 10-17-2005 01:52 PM |
How to drain the coolant completely? | SaturnRaycer | L-Series General | 1 | 07-04-2005 10:42 PM |
Block drain (coolant) question.... | gm7 | S-Series Tech | 11 | 05-22-2004 09:30 PM |
coolant drain plug? | gary078 | S-Series Tech | 1 | 03-07-2004 01:01 PM |
