Old 08-22-2009, 02:18 PM   #1
k1hog
k1hog is on a distinguished road
Default Wet floor boards, is sunroof drain lines the problem?
Floorboards wet on both driver and passanger side, are the sunroof drains the problem, as the head liner is not wet?
Thanks
Johnnie
k1hog is offline   Reply With Quote
Old 09-07-2009, 10:46 PM   #2
Noogit
Noogit is on a distinguished road
1992 SL1
Default Re: Wet floor boards, is sunroof drain lines the problem?
A friend had this problem in his '94 SL2. Turned out to be A/C condensation.
Stock '92 SL1.
Mods to come...
Noogit is offline   Reply With Quote
Old 09-08-2009, 05:34 AM   #3
velleguy73
velleguy73 is on a distinguished road
2001 SL
2002 SL
Certainly could be. Is it more in the front or the back? I'd run down your drain tubes 1st. If you use the search function, somebody posted pictures and schematics of the exit points.
Be sure to always post the year make and model of your car. The sunroof design changed between 96-97.
velleguy73 is offline   Reply With Quote
Old 09-08-2009, 10:15 AM   #4
PIYIRIO
PIYIRIO is on a distinguished road
On the passenger side, under the hood and close to the windshield, there should be a foam oval that looks like a 4 inch "0" with a plastic screen on top. If the glue on that is letting loose, it'll practically flood the floorboards if it rains or you wash it. It happens on both passenger and drivers side. I thought my sunroof was leaking but it was dry and it turned out that foam was just sitting over that hole with no glue/seal holding it down.
PIYIRIO is offline   Reply With Quote
Clogged Sunroof Drain Lines Gumart1 S-Series General 16 07-28-2009 07:46 AM
Water on floor boards oldguard L-Series General 2 06-12-2008 09:17 AM
floor boards rusted at driver seat JS593 S-Series General 7 10-27-2005 03:19 PM
anybody else have wet floor boards? texan Vue General 7 08-05-2003 08:23 AM
Wet floor/sunroof??? Plastic Gravity S-Series Tech 3 04-11-2002 04:53 PM
