Old 05-12-2009, 01:34 AM   #1
kenkennings
kenkennings is on a distinguished road
Default Burnt ground wire to ignition
How smart would it be to replace just the burnt ground wire with a thicker gauge wire? Im not sure what caused the problem in the first place but i figure if the gauge is bigger than it will have less of a chance to burn again.
kenkennings is offline   Reply With Quote
Old 05-12-2009, 09:15 AM   #2
Default Re: Burnt ground wire to ignition
Replace the ignition switch as fast as you can. The next phase of this failure is to burn up all the wiring that goes to the switch. When replacing the switch be sure to very carefully inspect he connector and the wiring. The switch is not the lock cylinder, it is behind it on the column and held in place with 2 screws. Not hard to change. The connector plug has 8 spaces in it. There is no fuse that will stop the short circuit current flow when it occurs so I would remove the battery negative cable and go purchase a switch.
SC2 burnt ignition switch wire Guy Harbaugh S-Series Tech 17 04-30-2015 02:01 AM
Sl1 95 burnt black wire to ignition indiana324 S-Series Tech 11 11-19-2014 12:14 PM
Burnt Black Wire Leading to the ignition?? indiana324 L-Series Tech 1 12-26-2008 09:06 PM
Burned Ground wire to Ignition apeskull96 S-Series Tech 10 09-06-2006 08:53 PM
ignition wire/spark plug wire - resistance/ohms Heartbeat - '95 SL2 S-Series Tech 3 10-17-2005 02:09 PM
