Old 05-07-2009, 06:48 AM   #1
Tommie
Tommie is a glorious beacon of lightTommie is a glorious beacon of lightTommie is a glorious beacon of lightTommie is a glorious beacon of lightTommie is a glorious beacon of lightTommie is a glorious beacon of light
1996 SL1
2002 SL1
Default How is misfire detected on Saturn SOHC?
This is a question for all you tech savy guys. Exactly how does the ECU determine engine misfire on the SOHC? Is it time interval on the teeth on the crankshaft?
Thanks in advance.
Tommie is offline   Reply With Quote
Old 05-07-2009, 06:55 AM   #2
Default Re: How is misfire detected on Saturn SOHC?
Try Differentracing.com for the technical explanation. There's another site also that rehashes the same basic information about electronically detecting misfires.
Old 05-07-2009, 08:59 AM   #3
Thanks in advance.
The short answer is the time difference between a given pair of notches with the engine at a constant RPM.
P0303 - Cylinder #3 Misfire Detected d4rkf1ber S-Series Tech 3 11-25-2019 04:14 PM
'00 Saturn LS 3.0L-Misfire Codes! Help! Kawabuggy L-Series Tech 12 11-11-2009 10:26 AM
Engine swap--99 SOHC auto/01 SOHC to fit in 96 SOHC stick comanche S-Series Tech 6 12-02-2008 07:57 PM
OBD Code: P0301 Cylinder 1 Misfire Detected hc803 S-Series Tech 16 01-22-2007 12:25 PM
Saturn SC! misfire ryder1964 S-Series General 15 12-13-2006 02:34 PM
