Old 11-17-2002, 01:34 PM   #1
jcurrieirocz
jcurrieirocz is on a distinguished road
jcurrieirocz's Avatar
Default trouble codes???? 26 & 32
Yep im getting these two trouble codes 26 & 32. Can anyone tell me what sensors they are for. Thanks
Jeff
jcurrieirocz is offline
Old 11-17-2002, 01:44 PM   #2
amazinghl
Default
26 Quad Driver output fault
32 EGR system fault
You probably need to change the EGR valve and the EGR solenoid.
00 Insight 72mpg
amazinghl is offline
Old 11-17-2002, 03:20 PM   #3
jcurrieirocz
Default
ok cool
what is a quad driver?
I know what the egr valve looks like, but what or where is the selinoid located,,,is there any way to test the selinoid to see if its bad?
Ill attach a pic of under my hood so you can point out this stuff for easy understanding.
Old 11-17-2002, 06:27 PM   #4
Default
EGR valve solenoid is located on the valve cover, back hump right side. It's bolted to the VC above the EGR. Trace the vac line from the EGR back to the solenoid. As for testing it with out the scan tools to run tests the only real way that I know of is to measure the resistance across the two terminals on the solenoid. Should be about 40-50 ohms, approx. These solenoids usually fail when hot. Best time to check is when the SES light is actually on. If the light won't come on for you pull the solenoid off of the car and sit the metal part of the solenoid on the exhaust manifold for a while to get it good and hot and then measure the resistance. Don't have the car running or you 'll have melted solenoid.
ssicarman is offline
Old 11-17-2002, 10:40 PM   #5
jcurrieirocz
Default
great i have a multimeter so what are the ohms if the selinoid(sp?) is failing, zero or highter then 50 ohms? It seems to make sence cause the light only comes on when car is hot or just before the temostat opens or sumting like that. Cause it goes of for a few mins then comes on again and stays for a bit again. Its on about 30% of the time I drive the car on longer trips.
Old 11-18-2002, 12:05 AM   #6
Default
It generally fails to very high ohms. Millions of. If it's anything more than a few hundred I would be suspect of it. Also if it's extremely low you may have a problem there as well. But usually it's the heat that makes it go to high resistance.
Old 11-19-2002, 12:35 AM   #7
92saturnsl2
92saturnsl2 is on a distinguished road
92saturnsl2's Avatar
Default
A bad EGR solenoid will trigger the code 26 as well as the EGR code. Replacing the EGR solenoid will most likely kill both birds with one stone...
92saturnsl2 is offline
saturn L300 trouble codes P0700 & P0727 kssbss L-Series Tech 14 07-10-2017 01:23 PM
Trouble with Transmission Trouble Codes Toaster_Man S-Series Tech 0 05-22-2008 07:32 PM
Trouble codes PO 411 & 440 dougyfd Ion Tech 2 04-02-2008 12:15 PM
Trouble Codes Lord_Dalamar S-Series General 1 04-04-2006 10:47 PM
Trouble codes CoolBreeze Miscellaneous Tech 0 09-23-2002 07:43 PM
