#1 |
![]() Join Date: Dec 2007
well the wifes ion has had the engine light on for a while now. but nothing seemed to be wrong to her enough to tell me about it. today she came home saying it was jumping and hesitating when she drove.
I just took it to autozone and got these 3 codes. po171 probable cause- if bank one and two codes set together suspect fuel pressure or MAF sensor. -ox sensor defective -ignition misfire -fuel injection problem po446 probable cause -purge or vent selonoids defective -check connector and wiring -fuel saturated vapor canister -failed evap vent selenoid po304 probable cause -ignition system fault/spark plugs/ ignition wires,coil -vacuum leak -injector fault -high or low fuel pressure so to me it sounds like from her explanation its seems to be misfiring. so 304 seems to be where to start. checking plugs and some injection cleaner. I searched and found they are having injector problems but this car has 58,000 and is out of warrenty. So i cant just drop it off and say fix it. ![]() any feedback on similiar situations or which way i should go please post up. |
#2 |
![]() Join Date: Mar 2006
2006 ION-2 Quad Coupe
id say replace the sparkplugs clear the codes and wait for the light to come on again..
VISIT MY CARDOMAIN --> http://www.cardomain.com/ride/2259877 s256 turbo, vulcan intake, exedy clutch, 8.9:1, camed, eagle rods, 2.4 tb, B&G coilovers, patriot head, stage 2 axels 418whp 2.2 :) |
#3 |
![]() ![]() Join Date: Aug 2002
2003 ION-2 Sedan
I'll second that. I'm on my third set of plugs at 90K kms. Plugs are cheap, if you need a reason to justify changing, price a coil pack and ignition module, the module usually goes first if the plugs go south without immediate attention.
Save the Earth, Ban Slushboxes!!!!! |
#4 |
sounds good. ill start there. thanks guys. can i clear the codes on this car the same as others by just disconecting the battary for a few minutes.
havent looked into it yet. are the plugs ontop or hidden somewhere. easy to get to like the older saturns. |
#5 |
right between the cams. No injector problems have been noted on any site I've been on, so I doubt it applies to our cars
2007 Saturn Ion 2 2003 Chevrolet venture lt trifecta dealer for the U.P. and WI. There is no two door ion. Proudly driving one of the last saturns produced before gm killed the brand. |
#6 |
new plugs and shes back up and running. engine light even turned off. good job guys
Bookmarks |
PO171 Code | NewTommie | Astra Tech | 6 | 02-21-2021 01:53 PM |
Help po171 174 lean codes cant figure out | saturnvue751 | Vue Tech | 4 | 11-07-2013 04:43 PM |
Codes PO171 & 174 | JerryH | Vue Tech | 7 | 11-17-2009 09:58 AM |
p0446 | maximuscrates | S-Series Tech | 4 | 08-13-2009 11:05 AM |
P0304, P0341, P0410 codes all at once | nitsua y zarc | S-Series Tech | 2 | 03-17-2008 07:23 PM |
