Old 10-26-2008, 11:03 AM   #1
PiercedOne
PiercedOne is on a distinguished road
Default Codes 341 and 440
I have a 2002 sl2 with about 119,000 miles on it. My check engine light came on the other day. I went to autozone and they read the codes of PO341 (camshaft position sensor) and PO440 (gas cap code) that was on there twice.
The car runs great and everything so my question is what is needed to replace the cam shaft sensor? Also will this throw a code once and then stay on until I reset the light? Any help would be great appricated..
PiercedOne is offline   Reply With Quote
Old 10-26-2008, 11:44 AM   #2
westwind999
1999 SW1
Default Re: Codes 341 and 440
If you do a search you will find most of your answers.
No cam sensor for 341 , try cleaning the coil packs. Clear the codes and they might not come back.
Old 10-26-2008, 09:17 PM   #3
IYAAYAS
IYAAYAS is on a distinguished road
2000 SL2
2000 SL
I've had the same codes pop up on my 00 SL2. Changed the spark plugs and replaced the gas cap. That took care of it.
IYAAYAS
IYAAYAS is offline   Reply With Quote
99 SL PO340 & 341 codes. Belarus99 S-Series Tech 9 01-16-2010 05:49 AM
PO137/340 and 341 Mason648 General Saturn Discussion 4 06-27-2008 01:55 PM
Trouble codes PO 411 & 440 dougyfd Ion Tech 2 04-02-2008 12:15 PM
2002 SL2 error codes 341 & 442 dylanzachgabby S-Series Tech 2 01-15-2007 10:54 AM
code 341 bills33 S-Series Tech 8 09-24-2003 07:24 AM
