#1 |
![]() Join Date: Apr 2007
I have a 98 SL1 1.9 L with 138000 miles. My service engine light will come on and then go off at what seems at random. I took it to the Advanced Auto and they said the codes they were getting are PO137 340 and 341. I am not sure what these mean and how do I corect he problem. Any help would be appreciatd
#2 |
P0137= http://www.obd-codes.com/p0137, Possible Bad O2 Sensor
P0340= http://www.obd-codes.com/p0340 , Possible Bad CPS P0341= http://www.obd-codes.com/p0141 , Possible Bad O2 Sensor
Bryan 94SL2 HCE, "Pearl" 99 SL 94SL2 260K Miles 1/15 97SW2 266K Miles 2/15 Always 94SC1 340,501 Miles Org. Engine/Auto Trans 2/97-10/08 Gone 3/12 92SL1 05VUE 91SC |
#3 | |||
![]() Quote:
P0340 and P0341 both refer to the non-existent CAM position sensor. In our cars, they indicate a general ignition system problem, impairing its ability to "fake" the sensor signal based on when the #4 spark plug fires. To remedy, check/replace the spark plugs and wires, and make sure the coils and ignition module are properly grounded. Wolfman has several photos in his gallery showing how to do that. Last edited by madpogue; 06-27-2008 at 12:43 PM. |
#4 |
Thanks a lot for all the help, I'll go see if I can find the photos for the coils. Any idea what it will cost for the O2 sensor on the converter?
#5 |
You CAN buy O2 Sensors for inexpensive from your favorite flavor auto store. If you buy one from the dealer it will be at least $70 or more.
The Cat Converter is not something that is cheap either, unless you have connections thru a muffler shop. I'm sure you can get them cheap; but as I don't have the tools in my garage to weld a new Cat Converter in place. They would probably run you anywhere from $100-$300? Just taking a guess there, I'm sure there are others that would be able to give a more accurate monetary figure.
Bookmarks |
SES light on Code PO137 - Help please | 69buick | S-Series General | 2 | 08-11-2009 08:44 AM |
Code 301,302, 340--Need some help | jk3006 | S-Series Tech | 18 | 04-01-2008 07:11 AM |
Po137 | plmbst | S-Series Tech | 2 | 03-12-2006 12:39 AM |
$42,340 | BUBBLEMAN | Relay General | 22 | 07-18-2005 08:18 PM |
PO 340 camshaft positioning sensor | Gpuller | S-Series General | 5 | 01-30-2004 02:39 PM |
