Old 08-07-2007, 11:01 AM   #1
mehalski
mehalski is on a distinguished road
Default transaxle buss plate slightly melted
Have been having issues with 2001 sl2 1.9l A/T
4 months ago had tss fuse blow
Replaced fuse and all was well, until last week
Inspected Buss plate on top of valve body
has melted plastic in two connectors
Cleaned buss plate, connector, replaced battery,cleaned connections (at car and at battery, applied di-electric grease
Problem persists
I think im gonna go to the junk yard to get a replacment connector.
Can the buss plate be removed from the Valve Body? The dealer says the plate is part of the VB and is sold as such. Does anyone know where is might be able to get an exploded view of the VB? or if I can order the buss plate somewhere?
Still searching for this elusive electrical demon
mehalski is offline   Reply With Quote
Old 08-07-2007, 01:17 PM   #2
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
Default Re: transaxle buss plate slightly melted
Someone HERE should have an extra valvebody ,and parts .
If none offers ,then you can probably get the plate from (Whatever it Takes ) transmission parts P H 1-800-940-0197
You will then need to tell them it is for SATURN T A A T
V B parts section 741
It looks like they may be able to get you any part ,or all of the assembly.
Have A Great Day , it is YOUR choice !
Dr B is offline   Reply With Quote
Old 08-07-2007, 09:30 PM   #3
The buss plate should be availible seperately from the valve body. It can be replaced seperately from the valve body. You just need to remove the valve body cover and the cover plate on top of the valve body.
I would look into replacing the connector as well because if not melted a bit the terminals in it are likely now weak due to the heat from the melted buss plate.
Buss Plate connector on top of tranny Phredawgy S-Series Tech 2 02-16-2007 04:52 AM
Newcomer with transaxle computer programming question(just change transaxle on 94SL2) rayjr99 S-Series Tech 3 10-24-2006 06:26 PM
Buss Plate bruce633 S-Series General 3 12-31-2005 04:20 PM
Buss plate bruce633 L-Series General 2 12-31-2005 12:35 AM
melted headlights SICKION Ion General 19 09-12-2004 03:37 PM
