Old 02-14-2009, 04:48 AM   #1
PSYKO_Inc
PSYKO_Inc is on a distinguished road
2000 SL1
2004 VUE Red Line
Default Misfire at idle - P0301
I've searched quite a bit but haven't found a definitive answer. The car is a 2000 SL1 automatic with 112K. When it's moving the car runs great, but it has a slight stumble at idle. The stumble gets worse when the car is in park or neutral, and seems to run a bit better when I shift it into drive. It has plenty of power and drives great, just took it on a trip to SoCal and it had no problems maintaining 80mph on the freeway for hours at a time and giving me about 40mpg. It only throws the code when I leave the car idling for several minutes. I have installed new Autolite copper plugs and Bosch wires, and the valve cover gasket isn't leaking. Any ideas?
PSYKO_Inc is offline   Reply With Quote
Old 02-14-2009, 10:53 AM   #2
rickystarshine
rickystarshine has a spectacular aura aboutrickystarshine has a spectacular aura about
rickystarshine's Avatar
2005 ION-2 Sedan
Default Re: Misfire at idle - P0301
It could be an intake manifold gasket leak, this is a known problem on the 2000-2002 SOHC engines(like yours)
To test for this, start the car, spray brake cleaner at the intake manifold where it meets the head, behind the power steering pump(cylinder 1)
if you hear a change in idle speed, you have a leaking gasket, replace it.
2005 ION 2 5 spd 202,155 miles
2001 SL1 Auto 298,252 miles
1997 Sl1 Auto 163,266 miles
rickystarshine is offline   Reply With Quote
Old 02-14-2009, 04:43 PM   #3
eRic 02sc2
eRic 02sc2's Avatar
A code P0301 may mean that one or more of the following has happened:
Faulty spark plug or wire
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Faulty catalytic converter(s)
Running out of fuel
Poor compression
Defective computer
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
idle, misfire, p0301
Idle Misfire. OnDaGround S-Series Tech 6 10-20-2009 07:29 AM
Sat SL1 P0301 CODE ROUGH IDLE docusn1 S-Series General 4 12-17-2007 08:30 AM
OBD Code: P0301 Cylinder 1 Misfire Detected hc803 S-Series Tech 16 01-22-2007 12:25 PM
My saturn hates me (Misfire -P0301-) plainzwalker S-Series Tech 14 05-13-2005 03:32 PM
P0301 cylander1 misfire machine_man S-Series Tech 4 10-15-2004 10:48 AM
