Old 06-06-2023, 09:42 PM   #1
DanoVh
DanoVh is on a distinguished road
2004 VUE 2.4L
2005 VUE 3.0L
Default HELP with timing chain replacement
04 Saturn View 170,000 miles.
Hit a pothole & it stalls, find out the timing chain snaped! After inspecting, I find out the black plastic guide basically disintegrated. Upper bolt MIA & the bottom sheered completely off. I was able to get the stud out & replace the Chain, Guides, Cam Sprockets, Crank Sprocket, Oiler & Tensioner. All sprockets lining up as they should to the chain marked links. Try to start her up & get nothing. After some checking I find out I had it in TDC exhaust instead of compression when I replaced everything, so I redo it in TDC compression & still nothing, just a little backfiring, I'm definitely getting fuel & spark. After some more checking I see the Mark on the Harmonic balancer doesn't line up to the mark on the timing cover when in TDC compression, it's about 30 degrees advanced. How can that be when everything is keyed. Has anybody seen this before? Also, I've seen this video of a guy going through the four strokes & showing the cam lobe positions & they don't match what I have. Hoping somebody has some advice.
Link to the video: https://www.youtube.com/watch?v=cfMfVi9nL_A
Thanks for any help.
DanoVh is offline   Reply With Quote
Timing Chain Replacement tgggd86 S-Series Tech 11 09-07-2014 08:22 PM
Timing Chain Replacement - Trouble Setting Timing neeco S-Series General 13 10-31-2011 02:02 PM
SW2 Timing chain replacement busman S-Series General 6 08-31-2005 12:32 AM
DIY Timing Chain Replacement BlueDog S-Series Tech 8 04-29-2002 03:31 PM
timing chain replacement SIYAM S-Series Tech 2 02-10-2001 11:17 AM
