Old 06-27-2008, 09:47 AM   #1
Mason648
Mason648 is on a distinguished road
Default PO137/340 and 341
I have a 98 SL1 1.9 L with 138000 miles. My service engine light will come on and then go off at what seems at random. I took it to the Advanced Auto and they said the codes they were getting are PO137 340 and 341. I am not sure what these mean and how do I corect he problem. Any help would be appreciatd
Mason648 is offline   Reply With Quote
Old 06-27-2008, 11:23 AM   #2
2NDSOUT
2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light
2NDSOUT's Avatar
1994 SL2
1999 SL
Default Re: PO137/340 and 341
P0137= http://www.obd-codes.com/p0137, Possible Bad O2 Sensor
P0340= http://www.obd-codes.com/p0340 , Possible Bad CPS
P0341= http://www.obd-codes.com/p0141 , Possible Bad O2 Sensor
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 06-27-2008, 12:30 PM   #3
madpogue
1996 SW2
This is in reference to the REAR O2 sensor. It's in the outlet of the catalytic converter. Typically it means just the sensor is bad, but if you are having performance problems, and if your exhaust feels weak out of the tailpipe, suspect a failing catalytic as well. You may not have much choice anyway, as (according to one of our techs [Squareback?]) the rear O2 sensor was frequently cross-threaded on installation at the factory, and with years of rust and heating/cooling, that sensor may not budge.
The CPS this article refers to is the CAMshaft position sensor. Our cars don't have one. With the S-Series, ANY mention of the CPS refers to the CRANKshaft position sensor. The two have nothing to do with one another. AutoZone is famous for selling S-Series owners a CPS when they throw a 340 or 341, when they have NO need for it. At one point, it was even listed as an "alternate" when you searched for a (non-existent) cam position sensor on their web site (I *THINK* they've remedied that).
The link is to a page on P0141.
P0340 and P0341 both refer to the non-existent CAM position sensor. In our cars, they indicate a general ignition system problem, impairing its ability to "fake" the sensor signal based on when the #4 spark plug fires. To remedy, check/replace the spark plugs and wires, and make sure the coils and ignition module are properly grounded. Wolfman has several photos in his gallery showing how to do that.
Old 06-27-2008, 12:58 PM   #4
Mason648
Thanks a lot for all the help, I'll go see if I can find the photos for the coils. Any idea what it will cost for the O2 sensor on the converter?
Old 06-27-2008, 01:55 PM   #5
2NDSOUT
2NDSOUT's Avatar
1994 SL2
1999 SL
You CAN buy O2 Sensors for inexpensive from your favorite flavor auto store. If you buy one from the dealer it will be at least $70 or more.
The Cat Converter is not something that is cheap either, unless you have connections thru a muffler shop. I'm sure you can get them cheap; but as I don't have the tools in my garage to weld a new Cat Converter in place. They would probably run you anywhere from $100-$300? Just taking a guess there, I'm sure there are others that would be able to give a more accurate monetary figure.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
SES light on Code PO137 - Help please 69buick S-Series General 2 08-11-2009 08:44 AM
Code 301,302, 340--Need some help jk3006 S-Series Tech 18 04-01-2008 07:11 AM
Po137 plmbst S-Series Tech 2 03-12-2006 12:39 AM
$42,340 BUBBLEMAN Relay General 22 07-18-2005 08:18 PM
PO 340 camshaft positioning sensor Gpuller S-Series General 5 01-30-2004 02:39 PM
