![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2011
Does anyone know what size the instrument cluster bulbs are? I want to swap them with leds.
Thanks! |
![]() ![]() ![]() Join Date: Jan 2018
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
What year is your car ?
2002 L300 Sedan 2003 LW300 Wagon 2005 L300 Sedan |
Sorry.. 2003 lw200
I believe the stock part number is 2452MFX6.
The generic base size is B8.4 I suggest you go to Superbrightled.com website. Lots of information. I used their LEDs in my 02 L300 instrument panel.
#5 |
Thank you!
![]() ![]() Join Date: Mar 2011
Unless they come with this option your best to contact GM parts store and ask for the correct replacement bulb. LED replacement should only be a DIY at your own risk. This model is far too old to be retrofitting now. So do the right fixes first.
#7 | |
in my 2002 L300 with LED's without a problem.
#8 |
![]() ![]() ![]() ![]() Join Date: May 2008
hi russet and ibran- read this intriguing thread on led bulbs for the cluster and elsewhere in our L series jalopies. more precisely is there a load sensitivity , wire metal interference or computer peccadillos here?. so far no problem with my 01 L 100 in this area even after 20 years and almost 200k miles. no bulbs out in cluster so if it aint broke dont fix it. but want to be prepared. figure it will be a hand shredding event with a few clusterf@#$ks removing and reinstalling the cluster to access the bulbs. have replaced bulbs in taillights, headlights , dome light and 3d brake light. any warnings or further thoughts on rebulbing the cluster? thanks tons bob f
#9 | |
Remove a few screws and you pull it out the front.
#10 |
^I agree. This instrument cluster is rather easy to remove. You'll need to remove the bezel first. To the best of my memory there are for screws which hold it in place. Once the bezel is removed there are - to the best of my recollection - four 10mm hex head retaining bolts attaching the cluster to the dash board structure. When pulling out the instrument cluster I found it necessary to pull the steering wheel tilt as low as possible to give it the necessary clearance for removal.
342,000 miles - Holy canolli! Biden/Harris - a done deal. Predictions, '21 -'25: a weak economy, a weakened military, increased terrorism and a greater RED CHINA. It would be good to be wrong. |
#11 |
I have the white faced gouges and was wondering if anyone has used a color led? Id.love to try blue and see how it would look.
#12 |
hi ibran and pierrot- thanks did not know that. most i have tried to remove risked breaking the plastic, emitting f bombs and with some shredded hands. regards bob f
Cluster bulb | BlueArmz | S-Series Tech | 8 | 11-26-2018 04:56 PM |
Need help with Instrument Cluster Bulb size | jenkneelind | 2008 Vue | 4 | 08-02-2013 09:02 AM |
Gauge Cluster Bulb | AuraDrvr89 | Ion General | 6 | 05-29-2012 03:48 PM |
SL2 Cluster Bulb # | MetalMatty | S-Series Mods | 4 | 02-29-2012 08:35 AM |
IP Cluster Bulb...again! | iondrivingfoo | Ion Mods | 6 | 12-06-2005 07:56 AM |
