Old 01-17-2005, 07:16 PM   #1
1991twincamsl2
1991twincamsl2 is on a distinguished road
1991 SL2
Attention This Is Important
My 1991 Saturn has a blown rod and it didnt start the day it happend, but it started today and i was wondering if there is something that i can replace, so I dont have to replace the engine!!! PLEASE HELP ME OUT
1991twincamsl2 is offline
Old 01-17-2005, 07:20 PM   #2
Razorbak
Razorbak's Avatar
Default Re: This Is Important
I'm not sure what you mean by "blown rod". Usually a "thrown rod" creates a large hole in the side of the engine block, making the engine lose oil pressure and become undriveable. What exactly happened, and what are the symptoms?
Razorbak is offline
Old 01-17-2005, 07:27 PM   #3
1991twincamsl2
1991 SL2
Information Re: This Is Important
I drove it down to put gas in it and on my way back it threw the rod, and it shut the engine off! I coasted it back into my drive way and now it sits is there anything i can do to replace that rod without replacing the engine! let me know
Old 01-17-2005, 07:31 PM   #4
Razorbak
Razorbak's Avatar
it threw the rod
What are the SYMPTOMS? A really bad noise, hole blown through the side of the engine block, oil dumped on your driveway, oil pressure telltale on the dash lit up?
Razorbak is offline
Old 01-17-2005, 08:10 PM   #5
sierrap615
sierrap615's Avatar
to some testing to confirm the engine has a mechanical problem, then pull it out and rebuild the engine
sierrap615 is offline
Old 01-17-2005, 08:28 PM   #6
1991twincamsl2
1991 SL2
Thats the thing i dont want to rebuild or swap engines if possible.
Old 01-17-2005, 08:29 PM   #7
1991twincamsl2
1991 SL2
The first too are the only thing that has gone wrong so far!
Old 01-17-2005, 09:33 PM   #8
Razorbak
Razorbak's Avatar
Oh... a hole blown through the side of the block. Well, that's easy. Just plug it up with a few wads of chewing gum and keep driving.
Razorbak is offline
Old 01-17-2005, 09:42 PM   #9
NavyCPO
NavyCPO is on a distinguished road
NavyCPO's Avatar
1993 SL2
Just don't use bubbleyum, it won't stick. :smiles:
Jim Hunter, Chief Petty Officer, USN, Retired
93 Saturn SL2 Automatic
NavyCPO is offline
Old 01-17-2005, 09:49 PM   #10
twosaturns
twosaturns's Avatar
o.k., let me see... you have a HOLE BLOWN through the side of the engine, and you don't want to rebuild it or swap it out? well, then, you have a nice saturn planter there, then. just park it, fill it with dirt, and plant some begonias.
twosaturns is offline
Old 01-17-2005, 09:56 PM   #11
sierrap615
sierrap615's Avatar
you could do it the cheap way but i doubt it would last three months. you don't even know whats all wrong yet, let alone why it failed. you need to do some detective work. start by - drain oil(look for metal shavings). remove timing cover(look for jumped chain). and remove oil pan(check crank/rods).
if you don't need a rebuild i will be very surprized.
Old 01-17-2005, 10:44 PM   #12
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
Please oh please tell me that post wasn't serious....the Block has a HOLE in it. There is NO WAY to use that block, it is officially a boat anchor. Replacing the block is the only way this car will ever run again. Best bet would be to look for a used engine from a junkyard, but remember 91 M.Y. has a lot of unique parts ie no torque axis mount, etc. Might be tough to find for a 14 year old car, and quite possibly, not worth the money.
SaturnTech is offline
Old 01-18-2005, 12:05 AM   #13
Razorbak
Razorbak's Avatar
So you don't like my bubble gum idea?
Razorbak is offline
Old 01-18-2005, 01:21 AM   #14
sierrap615
sierrap615's Avatar
duh stupid me, i was assumeing the hole was in the oil pan. maybe he can save the head.
Old 01-18-2005, 01:24 AM   #15
sierrap615
sierrap615's Avatar
bubble gum won't work. use duck tape, if that doesn't hold, use JB weld.
Old 01-18-2005, 01:35 AM   #16
ry92sc
ry92sc is on a distinguished road
ry92sc's Avatar
1992 SC
lol you guys are funny, engine swapage is decently cheap Im looking at 700 bucks installed for a engine with 1/3 the millage and installed like i said So yea....If its(the car) in good shape and thats only what wrong Id swap the engine, if not sell it to a JY or your local saturn mechanic and move on
ry92sc is offline
Old 01-18-2005, 02:17 AM   #17
Razorbak
Razorbak's Avatar
Oh, come on. It's just a little bitty hole...
http://www.saturnfans.com/photos/sho...cat/all/page/2
Where's your spirit of adventure?
Razorbak is offline
Old 01-18-2005, 12:00 PM   #18
1991twincamsl2
1991 SL2
Mine doesnt look as bad as what urs does...I will take in consideration of what u all said....Im gonna get some pics of the damage today after school...if u guys wanna see the damage look me up on cardomain.com my sn is 1991twincamsl1
Old 01-18-2005, 12:19 PM   #19
SaturnTech
SaturnTech's Avatar
doesn't matter how bad it looks...if there is a hole in the block, the ONLY fix is to replace it.
Old 01-18-2005, 12:26 PM   #20
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
Buddy, if the block has any hole in it, the engine is toast.
OK, lets assume you can fix the hole. (You can't but assume you can)
Then......
Take all the stuff off the left side to get to the timing chain.
Remove timing chain, intake, exhaust, pull heads (3 days later)
Fix screwed up head (Aluminim weld, grind, flatten, bla, bla, bla $300 later)
Now that the heads are off, look at broken piston, pull oil pan and stare at bent or broken crank.
Stare some more.....
Put parts into trunk, take to junk yard.
While you are there, look for another engine....
alleninpa is offline
Which O2 sensor is most important? postmortal1 S-Series Tech 7 11-16-2009 06:12 PM
How important is ABS? ducklet Ion Tech 19 09-21-2005 08:15 PM
Important Please Read All Garland Mods and Performance 7 09-12-2001 10:09 AM
