Old 10-20-2007, 11:04 PM   #1
IBEME
IBEME is on a distinguished road
1993 SC2
Default scanning tool '93 sc2
I've been trying to find a scanning tool to use on my '93 sc2 That sells for a decent price. So far no luck. If you know of one, give me a post. Thanks.
IBEME is offline   Reply With Quote
Old 10-20-2007, 11:13 PM   #2
deadmeat3344
deadmeat3344 is on a distinguished road
1991 SL2
Default Re: scanning tool '93 sc2
code readers are cheap but ones that graph and give you the imporntant stuff are NOT cheap.
Saturns are slow
deadmeat3344 is offline   Reply With Quote
Old 10-20-2007, 11:28 PM   #3
Special Forces
Special Forces has a spectacular aura aboutSpecial Forces has a spectacular aura aboutSpecial Forces has a spectacular aura about
Special Forces's Avatar
2006 ION Red Line
Are you looking for something to read trouble codes or looking for one to show you engine stats?
I believe OBD I cars you can just insert a paper clip in the interface in the right holes and the amount of times of the light blinks gives you the code.
/// Need rebuilt valve bodies? PM Me. \\\
//// Why bother with ebay when I'm right here? \\\\\
Valve bodies built to order
Please PM me about valve bodies, do not post a visitor message.
Special Forces is offline   Reply With Quote
Old 10-21-2007, 05:29 AM   #4
eljefino
eljefino's Avatar
1995 SW1
Keep an eye on ebay for OTC brand stuff.
Their OBD-I line comes with atari-style cartridges and plug "dongles" for various cars; GM generic will work with the saturn but make sure the cartridge is 93 and newer.
Old 10-21-2007, 04:27 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
you can get an Actron code scanner for $30 that will flash the "check engine" on a 1991-95 Saturn. look on www.autozone.com in the repair guides
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Need pic of cam sprocket retention tool and valve spring removal tool sr20fd3st S-Series General 2 07-13-2009 10:41 PM
problem scanning codes sl2ner08 S-Series Tech 3 09-24-2008 11:11 PM
Thoughts On This Real Time Scanning Tool Mike1969 S-Series General 5 06-15-2006 05:29 PM
What Tool Do I Use tamhan S-Series Tech 1 07-24-2005 02:45 PM
Scanning ABS codes Hiddenlites S-Series Tech 6 04-13-2003 06:36 PM
