Old 10-03-2022, 06:26 PM   #1
Timmahh
Timmahh is on a distinguished road
Wrench 2000 SL2 transmission clunk
I have a 2000 saturn SL2 that I had a transmission put in about 10 months ago. lately here it's been making a thud or clunk when I put it in reverse. It only happens when I put it in reverse. I've had the engine and transmission mounts checked and they are all fine so what could be causing this and how do I fix it?
Timmahh is offline   Reply With Quote
Old 10-03-2022, 10:20 PM   #2
Waiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to behold
Default Re: 2000 SL2 transmission clunk
One of the automatic transmission guys or gals will be along shortly. Sounds like a loose ISN (input shaft nut) or a reverse slam. Search those terms on the forum while you wait for someone more helpful.
Old 10-04-2022, 09:35 AM   #3
trottida
trottida's Avatar
Not really an automatic guy but I've read enough to know what's going on. The start of "reverse slam" is caused by sludge in the passages of the valve body caused by poor maintenance. The passages for reverse are where it first shows. The transmission fluid and filter must be changed at the appropriate intervals. If you leave it too long then the input shaft nut loses torque and starts to back off. Eventually you start losing other gears; if a recall correctly second is the next to go and that is caused by the input shaft nut issue.
If you catch it early you can perform the "Wolfman reverse slam cure" procedure. Wolfman was a Saturn technician and member of this forum. Read this post for more information.....Reverse "Slam" Cure in Saturn Autotransaxles.
If you left it too long then your into replacing the valve body and re-torqueing the input shaft nut. Sometimes you can get by with just the valve body. The valve body with the Sonnax upgrade is the preferred one. The are a couple of suppliers. Ken Partin Transmissions is one that comes to mind. He has a website and sells on eBay. He is very helpful and easy to work with from what other forum members have said. Here's the procedure to replace the valve body >> Valve Body Replacement
Here's the attachment that Chazberry created on replacing the input shaft nut. Click on it and it will download a pdf document >>ISN Tips
1999 SL2 MT (299,400 km @ 11/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 10-09-2022, 07:55 PM   #4
ZepSL2
ZepSL2 is on a distinguished road
I had this happen on my other Saturn. Do not wait jump on it now. Get
a trans and valve body pressure flush if you wait too long then you gotta
swap valve body. You need to get all the gunk outta there.
you know the slam is trans issue if it takes more than a few seconds for reverse to engage.
you know it is an input shaft nut only issue if the trans engaged quickly but you still get the slam.
If you wait too long to fix the trans the constant slams will loosen the input
shaft nut and then you gotta fix both.
1999 SL2 DOHC
ZepSL2 is offline   Reply With Quote
transmission
2000 SW2 Rear clunk over bumps SL19302 S-Series Tech 31 10-04-2015 09:07 AM
2000 sw2 front end clunk bluefever S-Series Tech 2 09-15-2014 08:55 AM
SL2 Transmission CLUNK Hmadden S-Series Tech 1 04-13-2013 06:07 PM
2000 sl2 series - BIG clunk from park to reverse masesmom L-Series Tech 2 03-12-2012 02:24 PM
transmission clunk 98 sl1 seadog95 S-Series Tech 6 10-24-2005 01:50 PM
