Old 09-19-2022, 06:55 PM   #21
cgg17
cgg17's Avatar
1995 SW2
Default Re: Saturn SL-1 clutch not *fully* dis-engaging
I would still recommend changing the hydraulic system, but it is a good sign that the pumping has helped.
If it had a large leak I would think you'd loose some clutch throw with that.
Try pumping the clutch, then holding it down for a minute or two with the car in 1st gear. If there is a large leak, it will bleed down and start to creep forwards as you lose pressure in the system due to the leak. If not, I would assume there was some air that had to be bled out of the system.
Regardless, it may be wise to replace the hydraulics, unless you are able to get this set to produce and maintain (over time) the proper amount of travel at the fork.
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018)
1994 Sl1 5spd: Inherited, Stock: 494,500
1995 Sl2 5spd: Retired Daily, Not Stock: 196,000
1995 Sw2 5spd: Daily, Stock: 105,000
Old 09-19-2022, 09:28 PM   #22
Waiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to behold
I wouldn't steer you wrong - the clutch bleed technique that holydiver posted back in 2011 is a good one!
AC clutch not engaging Tyson L-Series Tech 2 07-02-2019 02:46 PM
Replaced clutch now it wont engage fully tsdfab Vue Tech 22 07-07-2016 09:20 PM
Clutch not releasing fully? Ark S-Series Tech 3 02-22-2012 09:18 AM
Clutch not fully disengaging. GAlt S-Series General 15 12-31-2011 06:29 PM
LS1 clutch not engaging gdr L-Series General 3 05-06-2006 07:43 AM
