Old 06-28-2022, 05:31 PM   #1
benjie0426
benjie0426 is on a distinguished road
2009 AURA XR
Default O2 sensor for saturn Aura XR v6 3.6L engine
Hi, I got codes for bank 2 sensor 2 O2 sensor, but I'm not sure which side bank 2 is. I know sensor 2 is downstream -- after the catalytic converter but can't figure out the bank. Please help
benjie0426 is offline   Reply With Quote
Old 07-01-2022, 11:26 AM   #2
Default Re: O2 sensor for saturn Aura XR v6 3.6L engine
Tried reading your owner's manual for info? If not there then perhaps a call or visit a GM service center and ask. All service manuals, manufacturer or aftermarket (Chilton or Haynes) will have this.
Old 07-01-2022, 11:54 AM   #3
benjie0426
2009 AURA XR
I got a code for my O2 sensor and it says bank 2 sensor 2. I know that it's a downstream sensor (after the catalytic convertor) but I'm not sure which side bank 2 is for my car.
Old 07-03-2022, 05:46 AM   #4
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
The sensor is located on the downstream side of the converter towards the front of the car.
2008 Saturn Aura XE 3.5L 4 spd (Retired)
Old 07-03-2022, 01:51 PM   #5
All "V" engines have one bank slightly offset to the rear of the other. The forward bank begins with cyl. #1 (then 3,5,7, etc.) the other begins with cyl. #2 (then 4, 6, 8, etc.). This rearward offset bank is typically regarded as "Bank 2." In a transverse mounted "V" engine the rearward offset is toward the driver's side.
382K miles (engine replaced @ 375K).
Biden/Harris predictions, '21 -'25: weak economy; weaker military; more terrorism; emboldened RED CHINA. Sadly, B & H are proving me correct.
O2 sensor for saturn Aura XR v6 3.6L engine benjie0426 S-Series General 2 06-30-2022 11:33 PM
2000 Saturn SL2, Self Revving Engine, Coolant Sensor or Throttle Position Sensor? aygc271 S-Series Tech 5 08-06-2018 08:39 PM
Saturn Aura XE 3.5l Engine seized steverenio Aura General 14 10-25-2017 11:28 PM
00' Saturn SL2 Engine Coolant Sensor Replacement? oifdustin S-Series General 1 12-14-2012 10:51 PM
