Old 09-20-2012, 07:03 PM   #1
yesimalex
yesimalex is on a distinguished road
Default Brass temp sensor problem
I ordered 2 oem direct fit two wire temp sensors for my 92 sl2 the new one is keyed differently and caused a code 14 to pop up.
i.imgur.com/DJjpH.jpg
Otherwise it is identical. Yes I just shoved it on. Is this just the wrong part? Or is there a polarity to these and I installed it backwards.
Add to yesimalex's Reputation
Rate the quality of this post and help yesimalex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yesimalex is offline   Reply With Quote
Old 09-20-2012, 07:10 PM   #2
magtec
magtec will become famous soon enough
1995 SW2
Default Re: Brass temp sensor problem
link to image
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 09-20-2012, 07:20 PM   #3
yesimalex
The newb that I am is apparently not allowed to post links.
Couldn't really get a picture to show the keys very well. So sorry for the finger painting.
Old 09-20-2012, 07:24 PM   #4
fetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nice
1996 SC2
1997 SW2
The old part is the 2 wire PCM sensor, the new part is the single wire gauge sender. Move it to the upper single wire connector location then go try again with the parts counter guy, tell 'em you have a '98 instead of a '92 and you'll get the right part for the 2 wire sensor.
Old 09-20-2012, 07:36 PM   #5
yesimalex
Unfortunately I was the parts counter guy when I ordered these from rockauto.
I just like that cleaning the couch out covers my stupidity.
Thanks.
Old 09-20-2012, 07:38 PM   #6
1996 SC2
1997 SW2
Thanks.
At least you can still use the part with their screw up, the parking brake cables I ordered on the other hand I lost over $25 to the bums 'cause they put the wrong part in the right box.
Old 09-20-2012, 08:18 PM   #7
magtec
1995 SW2
it made me giggle.
Old 09-20-2012, 09:23 PM   #8
yesimalex
HAHA hey it got the information I needed!
My local advance has a temp sensor in stock (checked for 98 not 92 as suggested) The picture shows two keys in the center, I'll definitely verify that before leaving the store.
I got an O2 sensor as well, and it seems to be identical but I haven't had time to replace it yet. It has a connector and does not require any splicing.
The test drive with the wrong temp sensor still lead to a stall and rough running, which seems to point to the purge solenoid. It is still throwing a code for the O2 sensor and the quad driver. Better not rain this weekend.
Air temperature sensor (brass tipped) David 93 SL2m S-Series Tech 13 05-12-2007 12:34 AM
Brass ECTS sensor Joe315 S-Series Tech 8 09-11-2006 09:44 AM
brass air temp sensor? ASE_Tek0312 S-Series General 8 03-14-2006 04:21 PM
Really Strange Temp Sensor Problem Matt42 S-Series General 8 10-21-2005 01:43 AM
Coolent Temp. Sensor problem Da_Rockwilder12 S-Series General 22 01-22-2005 04:22 PM
