Old 04-04-2007, 02:51 AM   #1
ricrok1
ricrok1 is on a distinguished road
Default 1993 Saturn SL1 starting problem
Hello My friend recently bought a 93 saturn sl1 It ran fine till the other day It overheated they ended up replaceing the radiator since the popcock on the old one was screwed up well after putting the new one in it won't start when they told me I sat and thought about it if it overheated it might of messed up the ect sensor which Is like a crank sensor ( I think ) does anyone know if my thinking might be right.
Add to ricrok1's Reputation
Rate the quality of this post and help ricrok1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ricrok1 is offline   Reply With Quote
Old 04-04-2007, 06:10 AM   #2
Default Re: 1993 Saturn SL1 starting problem
Welcome to Saturnfans! No, don't confuse the engine coolant temperature sensor (ECTS) for the crank position sensor (CPS). They are two different animals, one is for measuring the coolant for data sent to the engine control computer to set the air/fuel ratios while the crank position sensor (CPS) is monitoring the crankshaft revs in order to send data for running the fuel pump and enable the ignition system to provide spark pulses.
Overheating won't damage the coolant sensor but look in the How-to section for this info on replacement, causes, etc..
Describe the symptoms with more details such as miles, any maintenance, etc., the more info given the less guessing on what's done or not done. Has the overflow cap been replaced? Does the radiator fan work?
Old 04-04-2007, 10:21 PM   #3
Coolant temp sensor may be more the reason that the car over heated.
As for the no start.
Check the basics. Do you have spark? Fuel? Fuel pressure? Fuel injection working?
Add to ssicarman's Reputation
99 Saturn Sl1, Idle Speed, And Starting Problem guitarguy2 S-Series Tech 8 02-04-2012 10:25 AM
Starting Problem - 1992 Saturn SL1 bungleodeon S-Series Tech 9 06-16-2009 06:32 PM
96 Saturn SL1 intermittent starting problem DMBFan L-Series Tech 4 02-14-2008 11:48 AM
95 sl1 starting problem sitdrew S-Series Tech 3 01-22-2008 07:22 AM
99 SL1 Starting problem after each fill up sl4me S-Series Tech 11 04-10-2007 08:14 PM
