#1 | ||||
![]() Join Date: Sep 2002
![]() Hi everyone,
I recently went to Saturn to have my oil changed (lifetime oil change program). Anyways while i was there the tech informed me of several issues with my car. I would like to get your guys opinions on how easy it is to do these myself. A few weks prior I changed the plugs and wires, pcv and by myself and will be attempting front brake pad replacement soon. I have some technical expertise and am willing to learn how to work on my car even if it takes all weekend to do a simple job. My main problem is tools and space. Right now i live in an apt but i can drive to a friends or my parents if necessary to get tools or work in a garage. Here is the list and prices quoted: serpentine belt $79 air fuel induction service $99.99 valve cover leak $210 resonator leak $325 strap and hanger part of muffler $129 I read about the valve cover repair so I am considering that repair. BTW i drive a 99 SL2 with about 111k miles on it.
#2 | ||||
![]() I know the strap/muffler hanger deal is an easy job. I just did mine about 2-3 weeks ago and it took about 45 minutes to do. I payed about $25 with shipping if I remember correctly from 6thPlanet (it was a used part, but good condition). The hardest part was figuring out how to get the new one on. I ended up having to grind a couple of corners down to make it easier. Definitly a DIY job, just make sure you have a access to a lift to make the job a little easier.
The valve cover problem is relativly easy. I attempted one on my 99 DOHC engine, just to find out I had the wrong gasket, but the original was still good. That job took me about 2hrs (I de-oiled the cover and spent about an hour letting it dry). Thats another fairly easy job, just follow directions.
#3 | ||||
![]() When you do the front pad replacement for Brakes, it is fairly easy but may take you a couple of hours. The bolts that hold the calipers and pads in place sometimes have a tendency to get "welded" in place...so much to the point you will have to drench the bolts in liquid wrench or use a couple of cans of WD-40. My wife's old 92 SL1 had the front left caliper bolts almost impossible to get off, we worked on the bolt for about an hour before it came loose
![]() Take your time with the brakes, and if your rotors look worn or you have some warping on them, I would replace those as well, they run about $25 from your local parts store (autozone, advance auto parts, napa). Once you do brakes on a car you can pretty much do them on any car, they are all the same, just some are set up different...my friend's 99 ford is set up with these push pins that hold the calipers and brake shoes together...not very sturdy if you ask me...but then again he drives a ford, so that says everything right there.... ![]() ... Bryan 94SL2 HCE, "Pearl" 99 SL 94SL2 260K Miles 1/15 97SW2 266K Miles 2/15 Always 94SC1 340,501 Miles Org. Engine/Auto Trans 2/97-10/08 Gone 3/12 92SL1 05VUE 91SC
#4 | ||||
![]() Join Date: Apr 2005
1996 SC1
![]() saturn in my town just yesterday quoted me $125 for the valve cover gasket (not so muck a gasket in my case but a seal for a 96sc1. so i hear...) and $225 for input shaft nut retorque if reverse slam cure doesn't work..(had P0733 AND P0734 yesterday
![]() i live in an apt too, so i feel your pain. i break the rules all the time and do my minor repairs/fluid changes on the top level of the parking garage after the leasing folks have left for the day. ![]() tell me aout this lifetime oil change program. was it part of a deal for a new car purchased from them or can anyone get invovled? some fool traded mine in years ago and i gladly took it off their hands! it's been so great so far ( august 1999 purchased 68k in alabama's version of traffic ![]() ![]() vincent
#5 | ||||
![]() The program was offered at the dealership to me and I recieved a postcard in the mail about it. What it is, is you pay $59.99 up front and future oil changes are free. It pretty much pays for itself in 2-3 changes. Each time you get your oil change the cost per visit decreases. Basically after 10 visits in the program each oil change comes out to approx $6. The program lasts for as long as I own my car so it wasn't a bad program to get involved in.
#6 | ||||
![]() No one has mentioned the serpentine belt- so I'll throw in my .02.
Since you are doing the brakes, take off the wheel well splash shields(when you do the passenger side)- they are just held in with a few of the omnipresent 2 part clips(pry out the center , then remove the outer part) Find the belt tensioner pulley- should be adjacent to the top front of the wheel well- and you can easily get a wrench on there to loosen it- hold it loose while taking the belt off of any pulley(whichever one is within reach of your other hand.)Put the new belt on the same way- wrap around all but one pulley, loosen the tension, and slip onto last pulley. There should be a belt routing diagram in your engine compartment above the radiator if you need it. IMPORTANT:Keep the old belt in your trunk. Toss it in your spare tire well. They are great to have in an emergency. The belt costs ~$20, and will only take 5 mintes extra when you do the brakes...definitely an easy money saver DIY While you have the splash shields off, might as well inspect your dogbone motor mount as well. You'll notice it behind the crankshaft pulley(IIRC). Inspect the rubber bushings for cracking or deterioration PS...my house doesn't have a garage so I do all of my work on the street. And I live on a corner house, so there is some traffic. No one seems to mind though...
#7 | ||||
![]() Thanks guys for the response. It is sounding like i can save myself a bundle by doing these repairs myself. Not to sound silly but what does IIRC stand for?
#8 | ||||
![]() IIRC=If I Recall Correctly
BONUS another common one: IMO or IMHO In My (Humble) Opinion ...There is also a thread in the How To Forum, IIRC(this is an interactive lesson ![]()
#9 | ||||
![]() ok thanks i'll read the thread
#10 | ||||
![]() I agree with the serpentine belt replacement. So simple, actually anyone can do it! Can't see why the cost is so much to have it done? Good luck,
Jerry
#11 | ||||
![]() Regarding the resonator leak: I just had the resonator on my 99sl2 replaced at a local muffler shop. They cut the old one out and welded in a new one in about 20 minutes. I only paid $50 total.
Valve Cover leak: the Saturn dealership sold me the gasket kit for $29. I will be doing that this weekend. The how-to(s) on this site make it seem pretty easy. Fuel Induction Service: Not sure what they are going to do here but I would wager it is just cleaning the Throttle Body and maybe some injector cleaning. I followed the how-to on that one and it took about 1.5 hours from start to finish. I noticed the difference right away.
#12 | ||||
![]() the tech told me my throttle body was sticking so i think the induction service was just a cleaning.
#13 | ||||
![]() [QUOTE=plainzwalker]I know the strap/muffler hanger deal is an easy job. I just did mine about 2-3 weeks ago and it took about 45 minutes to do. I payed about $25 with shipping if I remember correctly from 6thPlanet (it was a used part, but good condition).QUOTE]
i paid $26 for the brand new part from the saturn dealership. sounds like joey's laughing all the way to the bank... s3aturnr ... "reno is a lot like maybury, except everyone's on crystal meth and prostitution's legal" - junior
#14 | |||||
![]() [QUOTE=S3aturnR]
BTW.... that did INCLUDE express shipping and I got the part within a week. That alone is worth $26
#15 | ||||
![]() Join Date: Jun 2002
![]() You can do a very good cleaning your throttle body.. in less than 20 minutes.
Belt cost $20 at my local auto parts store. Like others suggested, go to a muffler shop for the resonator and muffler. You can have a system MADE for that much money!
#16 | ||||
![]() ![]() Join Date: Apr 2004
2009 AURA XR
1999 SL1
![]() Take the throttle body off to clean it. It only takes a couple of minutes.
It turns into a really funny story when someone has the flexable carb cleaner tip sucked into their engine.
#17 | |||||
![]() Quote:
... 1997 SW2 --> 'Vi' g/f's 2002 SL2 --> 'Raven' R4V3n SP33D's boytoy!
My Local Dealership closing | termite | General Saturn Discussion | 4 | 01-05-2010 10:49 PM |
**HELP* Car damaged at Saturn dealership...now what???** | SilverPlumGirl | L-Series Tech | 8 | 07-19-2005 06:45 PM |
Saturn SKY to be at my local dealership today | kellyanne67 | Sky General | 26 | 07-19-2005 12:23 AM |
whats in front of your local dealership | rossao1 | General Saturn Discussion | 32 | 01-13-2005 03:29 PM |
How Far is you local Saturn Dealership? | comcardi | S-Series General | 47 | 08-25-2004 12:21 AM |
