Old 01-07-2005, 08:01 PM   #1
"Sadurn"
"Sadurn" is on a distinguished road
Default 95 SC1 Air Dam.... GONE ! :-?
Hi Wise Ones! On my 95 SC1, the black plastic front air dam under the bumper just
fell off. It was hanging down a bit ever since I nailed a HUGE porcupine recently.
I think, that, plus hitting snow mounds, etc finally dispatched it without me knowing it.
I'm hoping this was just a cosmetic add-on but it also seemed to connect with a flat sort of
plastic shield that ran horizontally under the rad, fan, etc. That's gone too.
Soooo, what-a-ya think? Everything seems to still work ok but I'm wondering if it's
purpose was actually to protect the front of the engine/exhaust/O2 sensor area?
Thanks for any advice or past experiences.
Cheers, ..."Sadurn"
Add to "Sadurn"'s Reputation
Rate the quality of this post and help "Sadurn" reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
"Sadurn" is offline
Old 01-08-2005, 04:14 AM   #2
Magicman
Magicman has a spectacular aura aboutMagicman has a spectacular aura aboutMagicman has a spectacular aura about
Default Re: 95 SC1 Air Dam.... GONE ! :-?
On my sc2 i've been told it was to deflect air up to the radiator as well. Im not sure, does the sc1 let air thru the front of the car more then a sc2?
Add to Magicman's Reputation
Rate the quality of this post and help Magicman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Magicman is offline
Old 01-08-2005, 02:07 PM   #3
eRic 02sc2
eRic 02sc2's Avatar
replace it. i've been told by saturn engineering folks that it's used to direct air into the radiator and without it, there is a possiblity of saturns with air conditioning overheating in the summer. in winter it's probably no biggie, but you may want to replace it before summer when it's hot outside.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 01-12-2005, 12:46 PM   #4
"Sadurn"
"Doh!" Thanks guys. Well, I guess I'll be looking through some bone-yards this spring. In the mean time, everything is still working ok. Fingers crossed, haa-haa.
Cheers, ...Ken
"Sadurn" is offline
Old 01-12-2005, 03:04 PM   #5
Luke
Luke's Avatar
Fm >> eRic <<
>there is a possiblity of saturns with air conditioning overheating in the summer <
In addition, it should be stressed that the Air Dam is not critical, simply an added feature, to "contribute" to effecting cooling of the engine. It is a contributing factor, not a critical one. Time is not of the essence, in terms of replacing your lost unit.
Add to Luke's Reputation
Luke is offline
Front Air Dam Berry34 Aura General 34 07-05-2010 04:36 PM
Air dam question mr18436572 S-Series Tech 8 05-13-2009 03:30 PM
Question about the air dam mr18436572 S-Series General 32 04-21-2007 02:06 AM
Front air dam? Red97sc2 S-Series Tech 6 03-01-2007 02:05 PM
Air dam deflector......... Mark92SC2 Miscellaneous Tech 1 03-18-2003 06:19 PM
