Old 11-02-2019, 12:33 PM   #21
mjollnir79
mjollnir79 is on a distinguished road
Default Torque on crossmember bolts?
What is the torque on all the bolts related to installing a new subframe, crossmember? I have a HF torque, hopefully accurate. Should I use loctite?
Add to mjollnir79's Reputation
Rate the quality of this post and help mjollnir79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjollnir79 is offline   Reply With Quote
Old 11-02-2019, 01:34 PM   #22
Waiex191
Waiex191's Avatar
Default Re: Would this be enough to keep the engine stable while replacing crossmember/subfra
Cradle to Body Bolts 151 ft/lbs
I did not use locktite.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Will a 2001 DOHC S Series engine cradle/subframe fit my 2002 SL1 with a SOHC engine?? Doug427 S-Series General 3 11-29-2018 12:10 PM
Engine subframe replacement wi111y S-Series Tech 1 12-09-2013 09:05 AM
radiator mounting in replacing subframe ( '93 vs later years) NDtruck S-Series Tech 1 07-14-2010 09:40 PM
Replacing Front SUbFrame in 95' SL DevilDogMech S-Series Tech 8 08-14-2007 12:07 PM
Replacing An Engine Cradle Subframe? Matt42 S-Series Tech 10 02-05-2007 08:56 PM
