Old 09-13-2019, 07:25 PM   #1
chadandcindy
chadandcindy is on a distinguished road
Default computer issue or?
2002 SC- While driving today just shut off on the hwy,was able to coast and get into a parking lot. I turned the key off, then back on and it started right up? Sat and let it idle for a minute and when i put it in reverse it jerked into gear really hard but shifting to drive was smooth. I waited a minute and repeated and it did it again but the 3rd time was normal. Had to make 3 more stops before i got home and each time car started,shifted with no problem. Is this a computer issue, something in the security system causing the car to just shut off? Thanks
Add to chadandcindy's Reputation
Rate the quality of this post and help chadandcindy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chadandcindy is offline   Reply With Quote
Old 09-13-2019, 08:37 PM   #2
billr
Default Re: computer issue or?
It is not likely that the PCM (computer) is the problem, failures of those is petty rare, and an intermittent failure like this would be even rarer.
This is probably a problem with wiring, either in the power or ground wires. There are many places to check, so are you wanting to dig into this as a DIY project? If so, do you have an electrical multi-meter and the skills to use it (or want to invest in those)? If nothing else, check the cables that connect to the battery. Make sure those don't have any obvious looseness or corrosion. Next after that would be a connection at the fuse/relay block inside the cabin. It is often referred to as "F5" in this forum.
Add to billr's Reputation
Old 09-13-2019, 10:31 PM   #3
RobertGary1
Codes?
Old 09-14-2019, 10:00 AM   #4
Claybury
Claybury will become famous soon enough
Claybury's Avatar
Stop by a auto parts store and ask them to do a battery load test and an alternator test for you.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Add to Claybury's Reputation
Rate the quality of this post and help Claybury reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Claybury is offline   Reply With Quote
Old 09-14-2019, 10:01 PM   #5
chadandcindy
finally got a chance to go get a code check done. Heres the LIST i got-P0128 coolant thermostat, P0232 fuel pump secondary circuit high, P0446 evap emission system vent control circuit, P0789 shift timing solenoid, P01599 engine stall or near stall. I hadnt seen the other replies to get battery load test while i was there too. I've had problems with the fuel pump in the past so the P0232 is really a concern.
Old 09-14-2019, 10:56 PM   #6
Mileage, maintenance done, parts replaced? I think you mean P1599, a sideways hint of the engine stalling at random with several possibilities. This error may simply go away when the problem is found and fixed. Error code P0232 may be another false error as a result of the random engine die off. Last (random/false error) code P0789 about one of the shift solenoids not operating at the correct time. What these three error codes may have in common is their occurrence at the moment the engine randomly died unexpectedly then the pcm simply examines sensor data and spits out error codes. Each have their own circuitry to examine if you're willing to chase down each one but none aren't the cause of the engine randomly dying then restarting as if nothing occurred. Intermittent problems may one of the most difficult problems to address unless examined in a different perspective. The only error code that doesn't contribute to random engine die off is the P0128 error, possibly a worn out cold running thermostat. The simplest way to determine if the t-stat is underperforming, running colder than normal is to connect a reader and display actual coolant temps on a fully warmed up engine. You should expect to see between 185F-200F, no lower otherwise replace the t-stat.
The three error codes aren't killing the engine. The fuel pump circuit uses one relay from pcm commands to operate the fuel pump. The fuel pump fuse may be loose or have a faulty connection, the pump relay may be faulty or wiring is faulty. Replacing or reseating the fuse is one solution, replacing or reseating the pump relay is another solution. Wiring can be tested by measuring the command signal from the pcm (12v) and possibly a faulty pump ground connection by the trunk ground wire splices where pump ground may be corroded enough to create an intermittent pump issue. Several ground wires are tied together into a splice pack with one ring terminal connected to a chassis stud to provide ground. Several splice packs are around the vehicle. All usually grouping black wires as grounds.
Old 09-15-2019, 10:42 AM   #7
Claybury
Claybury's Avatar
Get the battery and alternator tested before you go down a rabbit hole of testing. Low or dirty bus voltage can cause many spurious codes.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
Old 10-03-2019, 12:54 PM   #8
S-forever
S-forever is on a distinguished road
1991 SL2
Definitely true that the electrics and charging system have to be right.
If the car is hot and intermittent engine stops happen - then it restarts after ten minutes or so, I'd suspect the CPS(crankshaft position sensor). It's cheap and not that hard to replace.
Add to S-forever's Reputation
Rate the quality of this post and help S-forever reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
S-forever is offline   Reply With Quote
2007 Ion computer issue? jimmay Ion General 4 06-13-2014 12:21 AM
'03 Ion2, Computer issue? rcote20 Ion General 22 02-24-2014 11:01 PM
Tranny/ computer issue? 08auraj Aura General 1 11-13-2008 07:29 PM
What have I done to my computer? puer liber S-Series Tech 3 03-05-2008 03:55 PM
My car is losing it's mind (maybe a computer issue?) dylanr_93SL2 S-Series Tech 9 08-10-2003 12:48 AM
