Old 08-31-2018, 10:32 AM   #1
Troll
Troll is on a distinguished road
Default Removeing AC pump from the serpentine loop
When I remove the AC pump what other changes will I have to do to to run the engine without AC?
Will most parts stores have the belt I need?
What will the changes in routing be and how will it effect the other belt driven accessories and tensioner?
This is posted in the general section as well, should I just have it over there only?
Add to Troll's Reputation
Rate the quality of this post and help Troll reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Troll is offline   Reply With Quote
Old 08-31-2018, 07:26 PM   #2
Default Re: Removeing AC pump from the serpentine loop
If you intend to remove the ac compressor, you can search past threads by others doing the same. Belt size is mentioned. While you're at it, removing the ac condenser coil and lines will allow better air flow thru the radiator and lighten the front end. Some say checking auto parts stores and asking for a non ac drive belt may work.
Old 09-01-2018, 08:57 AM   #3
laser3kw
laser3kw is on a distinguished road
2000 SC1
Originally Posted by SixthSphere SOHC belt lengths
All belts are 5 rib.
WITHOUT A/C WITHOUT PS
- 55.0 inches
WITH A/C WITHOUT P/S
- 63.5 inches
WITHOUT A/C WITH P/S
- 64.5 inches
WITH A/C WITH P/S
- 75.5 inches
The Autozone part numbers are just the length and then K5 for 5 rib....so the factory belt for an Sx2 is goign to be 755K5.
Removing the P/S requires a ribbed idler pulley.
As answered in your other post in Tech section,there are many variables depending on the configuration.
On my 2000 sc1, I used the above chart and picked the one that described my SC1, but without the AC. I removed the AC pump, left the bracket, and installed the belt. Done!
Add to laser3kw's Reputation
Rate the quality of this post and help laser3kw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
laser3kw is offline   Reply With Quote
Maintenance Update - Water Pump, Motor Mount, Serpentine Belt TXSaturn02 S-Series General 0 11-24-2010 06:26 PM
SC2 water pump and serpentine belt phunkygoz S-Series Tech 9 11-02-2009 12:24 PM
removeing a fuse? ion skater6912 Ion Tech 2 11-14-2006 08:57 PM
Removeing door panel blackice5386 Ion General 4 10-15-2005 06:41 PM
New serpentine belt = bad water pump? SLeepr Miscellaneous Tech 8 04-03-2003 06:31 PM
