Old 02-11-2015, 03:35 PM   #1
bobwalk
bobwalk is on a distinguished road
Default 2003 Saturn Vue BCM
I have a 2003 Saturn Vue, V6 with all options. Started having issues with gauges and power steering not working intermittently which eventually turned into total loss of PS and gauges. Car ran fine and everything else worked. Found a used BCM with exact same PN and replaced with 30 minute passlock procedure. Car started up fine, gauges and PS working, but now have no communication with ABS and traction control. Any ideas?
Add to bobwalk's Reputation
Rate the quality of this post and help bobwalk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobwalk is offline   Reply With Quote
Old 02-11-2015, 04:11 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2003 Saturn Vue BCM
I'm wondering if matching part numbers is all that's needed.
I'm no BCM expert but seem to recall if you bought new BCM from dealer they'd use original VIN number to determine which options were delivered with Vue and would program according - along with vehicle mileage.
Could your replacement BCM be from a 03 Vue without ABS?
I don't know if any were built without ABS but there's lots of smart 3.0 folks who will probably know.
I try to visit forum often but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 02-11-2015, 04:32 PM   #3
Chazberry
Chazberry's Avatar
1995 SW2
I'm thinking you need to find someone with a Tech II . . .
http://www.saturnfans.com/forums/sho...78#post2116878
Add to Chazberry's Reputation
Old 02-11-2015, 07:45 PM   #4
bobwalk
Far2Grumpy, I had the same idea and found out that ABS and TC were optional in the 2003 Vue so possible the vehicle the BCM came from didn't have those options. Does anyone know if a BCM from a vehicle that didn't have those options can be programmed with a tech II to make them work?
Old 02-12-2015, 12:24 PM   #5
bobwalk
New update. So after doing some research I determined that my 2003 Vue does not have ABS (J41 Service Part Code and only 2 wires on brake fluid reservoir). So now I am assuming that the BCM I received was from a Vue that had ABS and the ABS light is on because it can't find it. Is their a way to disable the ABS light or program the BCM not to look for it?
Old 02-12-2015, 01:08 PM   #6
Chazberry
Chazberry's Avatar
1995 SW2
I'm pretty sure you just need a reprogram.
Old 04-05-2015, 06:37 PM   #7
padlock1978
padlock1978 has a spectacular aura aboutpadlock1978 has a spectacular aura about
May need to take it on and have it programmed
My Rides
03 Saturn Vue Canary Yellow
99 F150. 5.4 Running Strong
89 Mustang 351W pushing over 400HP
Add to padlock1978's Reputation
Rate the quality of this post and help padlock1978 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
padlock1978 is offline   Reply With Quote
2003 Saturn Vue nix3b4u Vue General 1 08-19-2013 10:55 AM
2003 Saturn for $750 Beachbaby902 Vue General 17 12-12-2009 01:34 AM
2003 saturn vue chris montague Vue General 2 07-20-2008 09:08 AM
2003 Saturn Vue V6 cricket2006 Vue General 1 05-07-2006 11:14 AM
2003 saturn ion racegirlfor1 Ion General 21 09-06-2005 07:58 PM
