#1 | ||||
![]() Join Date: May 2014
![]() The lift gate on my 2005 relay is closed and I can't open it. How would I do so manually. It has happened a couple of times before but I would just try pulling the latch occasionally and it would open but not any more. There is no longer a dealer in my area. My key fob doesn't work either since replacing battery so really lost as to how to open lift gate. Thank you
#2 | ||||
![]() ![]() ![]() ![]() Join Date: Nov 2007
2008 Outlook XR
2007 AURA XR
![]() did you try unlock button from inside car? any gm dealer should be able to help. same tailgate as chev, buick, old pontiac co etc.
#3 | ||||
![]() Try pushing the liftgate into the minivan instead of pulling when pressing on the release handle, using two hands. Sometimes liftgates jam from wear and tear so doing the opposite may help unjam a stuck latch as you're relieving pressure on the latch mechanism. If you are successful opening the l/g, examine the door seal and latch for anything that looks out of the ordinary and decide if a little lube is needed (latch mechanism) or a trip to any GM dealer is necessary.
Stuck lift gate | temley | S-Series General | 2 | 05-20-2014 05:57 PM |
lift gate stuck | temley | Support Forum for Canadian Saturn Owners | 0 | 05-19-2014 11:43 PM |
Lift gate questions | Tim T | S-Series Tech | 12 | 12-07-2013 12:14 PM |
Lift Gate problems | kyad12 | Outlook General | 5 | 03-22-2007 10:11 PM |
lift gate struts | jslw300 | L-Series Tech | 6 | 02-15-2005 10:37 PM |
